Interrupt at pinswitch problem
5 posts / 0 new
Here I am again... :oops:
I have a circuit with LED's, and when an timer1 interrupt occurs sometimes I see the LED's switch on and off very fast.
Now I use cli to disable the interrupts before switching and sei to enable the interrupt again.
Now this fenomen is gone.
Is there an option/trick so that the interrupt cannot occurs only when a pin is switching?
So, the timer1 interrupt is controlling the LEDs or what?
If not, just use cli/sei... it should be fine.
Ok, another "trick" is to disable ONLY the timer1 interrupt and then to re-enable the timer1 interrupt (after you finish switching).
But, anyway... what is the cause of this strange behaviour?
Real men don't use backups, they post their stuff on a public ftp server and let the rest of the world make copies.
RoBSki,
Post some code and we can better evaluate what is happening. It might not be interrupts that are causing the problem. Hard to say without more details and the code.
-Will
Hard to say with more details and the code.
Rather easier... ? :wink:
Are you using the pin change interupt for other code?
-Curiosity may have killed the cat
-But that's why they have nine lives
