No data receiving via TWI
2 posts / 0 new
Hey guys,
currently i'm working with a xmegaA3BU xplained bord and a MAG3110 device.
I'm trying to get data from the MAG3110, but i don't get anyfrown
I have used TWI more then ones with other devices and have looked at the code from those projects. But i can't find anything.
void TWI_init(void){
	/* Zet Baud rate op 100KHZ */
	TWIC_MASTER_BAUD |= TWI_BAUD(F_CPU, Baud_rate);
	/* Zet Enable TWI master mode, Read interrupts mode en Medium interrupt lvl */
	TWIC_MASTER_CTRLA |= (TWI_MASTER_ENABLE_bm | TWI_MASTER_RIEN_bm | TWI_MASTER_WIEN_bm | TWI_MASTER_INTLVL_MED_gc);
	/* Dwingt Bus in idle mode */
	TWIC_MASTER_STATUS = TWI_MASTER_BUSSTATE_IDLE_gc;
	 /* Enables de interrupt lvl's high en medium */
	 PMIC_CTRL |= PMIC_HILVLEN_bm| PMIC_MEDLVLEN_bm;
	 SREG = (1<<7);//enable global ISR's
This is the function that i use to init the TWI.
void clock_init(void){
	/* De clock van de microcontroller wordt ingesteld op 2MHz */
	OSC.CTRL = OSC_RC2MEN_bm;
	/* Wachten totdat 2MHz klok enabled is */
	while(!(OSC.STATUS & OSC_RC2MEN_bm));
	CCP = CCP_IOREG_gc;
	CLK.CTRL = CLK_SCLKSEL_RC2M_gc;
	/* Enables the clock on TC1, SPI and TWI in the power reduction register */
	PR.PRPC = (TC1_clock_enable|SPI_clock_enable| TWI_clock_enable);
The clock will be set at 2MHz.
Also got a struct where all the address from the MAG3110 are initialised.
#define MAG3110_Adres 0x0C
#define MAG3110_XREG_MSB 0x01
#define MAG3110_XREG_LSB 0x02
#define MAG3110_YREG_MSB 0x03
#define MAG3110_YREG_LSB 0x04
#define MAG3110_ZREG_MSB 0x05
#define MAG3110_ZREG_LSB 0x06
#define MAG3110_WHO_AM_I 0x07
#define MAG3110_control_reg1 0x10
#define MAG3110_control_reg2 0x11
void MAG3110_init(void){
	MAG3110.Adres		= MAG3110_Adres;
	MAG3110.Adres_write	= (MAG3110_Adres<<1);
	MAG3110.Adres_read	= (MAG3110_Adres<<1)+1;
	MAG3110.X_value		= 0;
	MAG3110.Y_value		= 0;
	MAG3110.Z_value		= 0;
	MAG3110.Device_ID	= 0;
In the main i first activate the MAG3110 by writing a 1 to bit 1 in the controll register of the MAG3110 using the ISR of TWI.
After that i was first trying to read the variable registers of the MAG3110, but after severals times i didn't get anything.
So i am trying to read de device ID from the MAG3110 register.
#include <asf.h>
#include <MAG3110.h>
void TWI_init(void);
void clock_init(void);
void usart_init(void);
#define Baud_rate 100000
#define TWI_MASTER_STOP_bm 0x03
#define ARBLOST (TWIC_MASTER_STATUS & 0x08)
#define Acknowlegdment 0x02
Bool Bus_free = true;
Bool activate_mag3110= false;
#define TWI_clock_enable (0x20<<0)
#define SPI_clock_enable (0x08<<0)
#define TC1_clock_enable (0x02<<0)
#define WIF (TWIC_MASTER_STATUS & 0x40)
#define RIF (TWIC_MASTER_STATUS & 0x80)
SR(TWIC_TWIM_vect){
	static uint8_t ISRcounter = 0, ISRcounter2=0, Nummer = 0;
 	if(ARBLOST){TWIC_MASTER_STATUS |= TWI_MASTER_ARBLOST_bm; TWIC_MASTER_STATUS = TWI_MASTER_BUSSTATE_IDLE_gc; ISRcounter=0; return;}
		 if (activate_mag3110 == false) {
			 switch(ISRcounter2){
				 case 0:
				 if(TWIC_MASTER_ADDR == MAG3110.Adres_write){
					TWIC_MASTER_DATA = MAG3110_control_reg1;
					ISRcounter2 = 1;
				 break;
				 case 1:
					TWIC_MASTER_DATA = 0b00000001;//enable MAG3110 tot active
					while(!(WIF));
					TWIC_MASTER_CTRLC |= TWI_MASTER_STOP_bm;
					activate_mag3110 = true;
					ISRcounter2 = 2;
					Bus_free =true;
					break;
		 }else{
 	switch(ISRcounter){
		case 0:
 					TWIC_MASTER_DATA = MAG3110_WHO_AM_I;
 					ISRcounter=1;
 			break;
 		case 1:
 			TWIC_MASTER_ADDR = MAG3110.Adres_read;
 			ISRcounter = 2;
			break;
		case 2:
			MAG3110.Device_ID = TWIC_MASTER_DATA;
			TWIC_MASTER_CTRLC = TWI_MASTER_ACKACT_bm;
			ISRcounter = 0; Bus_free = true;
			break;
 int main (void)
	// Insert system clock initialization code here (sysclk_init()).
	uint8_t i=0;
	char format_buffer[16]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
	board_init();
	sysclk_init();
	clock_init();
	TWI_init();
	MAG3110_init();
	/*usart_init();*/
	gfx_mono_init();
	gpio_set_pin_high(NHD_C12832A1Z_BACKLIGHT);
	st7565r_set_contrast(ST7565R_DISPLAY_CONTRAST_MIN);
	gfx_mono_draw_string("Test tekst",0, 0, &sysfont);
	while(1){
		LED_Toggle(LED0);
		delay_ms(100);
		if(Bus_free == true && activate_mag3110 ==false && TWIC_MASTER_STATUS == 0x01){
			TWIC_MASTER_ADDR = MAG3110.Adres_write;
			Bus_free =false;
		if(Bus_free ==true && activate_mag3110 == true ){
			Bus_free =false;
		sprintf(format_buffer, "%16u", MAG3110.X_value);
		/*sprintf(format_buffer[1], "%16u", MAG3110.Y_value);
		sprintf(format_buffer[2], "%16u", MAG3110.Z_value);*/
		if(i==0){
			gfx_mono_draw_string(format_buffer, 5, 8, &sysfont);
			delay_ms(1000);
			i=1;
		}else{
			gfx_mono_draw_string("ok    ", 5, 8, &sysfont);
			delay_ms(1000);
			i=0;
	return (0);
Hope anyone can help me with it :)
PS: also added the project as attachment.
[EDIT]:
this is the MAG3110 that i'm using:
https://www.sparkfun.com/products/12670
DAMN i was stupid, i was trying to communicated with the wrong ADDRESS >.>
[EDIT]:
Also my write / read order was wrong. I was trying to read first then, but i need to change address to write first then, write in the DATA the address. After that change to read address and read the data from DATA register.
Greeting,
Rgamer145
