ATMega16L-8PU strange behaviour
3 posts / 0 new
I mada a really simple program. It must send a logical 0 to all ports in order to turn leds on. I put an ATMega16 8PU on the STK500 and I transferred the C code inside it. Nothing happened. All led off. The code was too simple so i thought there were something wrong with the microcontroller. I used instead an ATMega8535. The same code (no change were made) now works perfectly. What could be the problem? I have to use ATMega16 for a more complex project
Here's the code
#define F_CPU 40000UL  //4 MHz
	DDRA=0b11111111;
	PORTA=0b00000000;
	DDRB=0b11111111;
	PORTB=0b00000000;
	DDRC=0b11111111;
	PORTC=0b00000000;
	DDRD=0b11111111;
	PORTD=0b00000000;
EDIT:
The microcontroller was broken so i tested the program with other 2 ATMega16. All ports works perfectly exept portC. PC0,PC1,PC6 and PC7 have a logical 0 but the other pins has a logical1.
See my signature ;-)
I feel like an idiot. After a short search about JTAG i solved the problema. Thank you very much
