ICC compiler inefficiencies
3 posts / 0 new
After two months of using AVR tools including ICE200 and ICEPRO with AVR Studio and the ImageCraft compiler, I am both greatly satisfied with their capabilities and hopeful for future developments in the compiler. The following inefficiencies in particular surprised me:
1. Case statements that do not take into account the type nor possible range of the switch parameter. With a switch parameter of unsigned char, the case processing treats it as a signed word. It takes many cases before it is more efficient than if..else if..else construction.
2. There is no provision for 8x8=16 and 16x16=32 multiplies. This means that extra casting is required in the source and longer processing time than necessary.
3. Expression evaluation that occurs multiple times is repeated. A simple construct like
func(parm){} that includes the expression -parm more than once recalculates -parm every time.
I'm sure that others have observed similar problems. I would apreciate comments or other examples.
admin's test signature
A lot of this is down to the language definition. A few years back I drew certain compiler authors attention to a type promotion “bug”. Even quoted the appropriate part of the ‘C’ language specification to them. It turned out that the ANSI committee had since changed it, and so I was wrong! Personally I think a the ANSI committee made a few duff decisions, or at least they didn’t take minimal resource applications very much into account.
So don’t shoot the ‘C’ implementor until you determine that he’s not been following a necessary ANSI stipulation.
Your point 3 is called sub-expression elimination, and should be part of any decent optimizer. Are you sure the upmarket version of ImageCraft doesn’t handle this?
Terry
Hi Dave, please feel free to email me directly to continue with this. I'm very interested in your opinions etc. Specifically to answer your questions:
1) case value optimizations. Noted. I will need to think about how best to use the information.
2) 8x8=16,16x16=32. The problem is that there is no portable C way of expressing that. We can of course provide library functions for you to call directly. I will add that to the enhancement bin.
3) Common Subexpressions. Currently, we do eliminate CS in a straight block of code, but not across basic blocks. THat will be coming this Summer in our PRO version with classical optimizations.
// richard
Richard Man http://imagecraft.com
Beyond Arduino - When you're ready to get serious...
JumpStart C Tools, The Better Alternative.
