AtMega16 + HC-05 + Android Phone
13 posts / 0 new
I have two general questions. I have to connect an ATMega16 with and Android phone using bluetooth. The most used bluetooth module (and cheapest) seems to be the HC-05.
1.Is it necessary to configure the bluetooth module (with the AT commands) or can I just use it with it's default settings?
2. After settings and wirings are done, how does the communication between ATMega and Android phone works?
    (for example: If I send a byte through USART, does the Android phone receive it without doing anything else?)
So they should be in the General forum;  they have nothing specifically to do with megaAVR and tinyAVR - or any other particular microcontroller
Ok...i did a similar project to control my tank robot using bluetooth....no need to configure the HC05....By default,it will be in serial mode with 9600 baud....Just go ahead
Rgds//Sharanya
For your second query....Just download a serial communication software via bluetooth like..."BLUETERM" into your phone....then you have to pair with the HC05 and send data...thats it.On the avr side,you have to receive the data from the HC05 via it's Tx pin,connected to atmega's Rx pin.
The OP is asking about connecting the HC-05 to the Mega16, and then how to get the AVR communicating.
I'll leave this  for now.
JIm
JIm
I'm really sorry. It seemed the right section...
Anyway, it's just simple as it seems?
TX enable -> Put data in UDR -> The communication starts -> the phone (with the app mentioned before) receives exactly what i put on UDR
Is it correct?
exactly....first of all,connect avr Tx to HC05 Rx and avr Rx to HC05 Tx.Set up for 9600-8-n-1-n.Now write data to UDR for transmit to phone via HC05.Read UDR for data received via HC05 from phone.
What does 9600-8-n-1-n means?
9600 = baud rate;
8 = number of data bits;
n = NO parity bit;
1 = number of stop bits
Fairly standard notation for describing serial port settings.
(Don't know why the 'n' is repeated)
ha ha...thanks for watching....the last 'n' stands for no flow control...although it has no relation while setting up on avr.....
I see.
Well, if the HC05 requires it, then the connected device - whatever it may be - must provide it.
When i communicated with the HC05,it was not needed....without flow control,it will work properly........
Now it's all clear. Thanks everybody
