Where is ATmega8 ?
AVR Studio 4.17..... ATMega8 missing! (?)
The JTAGICEmkII only lists (even for ISP) the chips that have JTAG or debugWire.
If you want to use a JTAGICEmkII to ISP program a mega8 then either use avrdude or edit the XML files for mega8 to "lie" that it has JTAG
Cliff
I presumed that...
My AVR ISP MK II died last night. (MISO or MOSI grounded I believe), so I desperately looking for USB programmer before tomorrow. (or programmer wich work with usb-232 conversion FT232RL).
Like I say, avrdude has no qualms about using the jtagicemkii to do ISP to a mega8
Hi all, I am making a program in which I am interfacing LM75A (temperature IC) with Atmega8 using I2C and then getting the value of temperature serially to my laptop. I have written the code but I think there is some problem in it and that's why I am not getting exact output. please help.
Here is the code:
#ifndef F_CPU
#define F_CPU 8000000UL
#endif
#include<util/delay.h>
#include <stdio.h>
//Serial tansmit
void serial_avr(char *str)
UCSRB=(1<<TXEN);
UCSRC=(1<<UCSZ1)|(1<<UCSZ0)|(1<<URSEL);
UBRRL=51;
for (unsigned int i=0;str[i]!=0;i++)
UDR=str[i];
//UDR = 0;
while(!(UCSRA&(1<<UDRE)));
_delay_ms(500);
void i2c_init(void)
TWSR=0x00;
TWBR=0x47;
TWCR=0x04;
void i2c_start(void)
TWCR = (1 << TWINT) | (1 << TWSTA) | (1 << TWEN);
while ((TWCR & (1 << TWINT)) == 0);
void i2c_write(unsigned char data)
TWDR = data ;
TWCR = (1<< TWINT)|(1<<TWEN);
while ((TWCR & (1 <<TWINT)) == 0);
unsigned char i2c_read(unsigned char isLast)
if (isLast == 0)
TWCR = (1<< TWINT)|(1<<TWEN)|(1<<TWEA);
return TWDR ;
void i2c_stop()
TWCR = (1<< TWINT)|(1<<TWEN)|(1<<TWSTO);
void main(void)
char temp;
i2c_init();
i2c_start();
i2c_write(0b10010001); //slave address for LM75A
i2c_write(0x00); //temperature register address
temp = i2c_read(1);
i2c_stop();
serial_avr(temp);
_delay_ms(2000);
Why have you posted to this thread? You question has no relevance to the thread subject?
BTW your code makes no sense whatsoever. The i2c_read function returns a "char", you assign it to "temp" but then you pass this as a parameter to serial_avr() as "char *" not just "char" then you treat it as if it were a string?
I'm astonished the C compiler even compiled this without error - there MUST have been a warning at the very least when you used "serial_avr(temp)"?
Anyway if you want to convert a 0..255 value to a string of ASCII digits to show on a terminal you need to use a numeric to string conversion routine such as itoa() or sprintf() or similar.
(also is "char" the right type anyway - at the very least I guess you mean "unsigned char"?)
How can I post new questions here.?
