ATXMEGA128a4u-accesing other USARTs..
6 posts / 0 new
Hi everyone.
I have a question regarding using more than 1 USART on the ATXmega128a4u.
I have a board that incorporates an ESP8266 wifi module connected to USARTC0 that is sent through a USB port using CDC.
The board has all pins broken out except for pins PC2 & PC3 which are connected to Tx and Rx of the ESP board.
I would like to know how I would go about accessing another USART to have information passed to it from the ESP8266.
I know the ATXMEGA128a4u has 5 USARTS but am not sure how I would go about setting up another USART.
Could anyone please help me with this?
The schematic for the board is in the attachment.
Thanks.
STeve.S
The datasheet says the 5 USARTs are identical - so you can just duplicate your USARTx code, replacing all UASRTx references with USARTy
It is debatable when it becomes preferable to make a "generic" driver for any USART as opposed to just duplicating the code.
But, for generic code, ASF has already done that for you...
I have drivers for each USART, same code as above but changing the USART name ie
xm_usartc0_s.c, xm_usartd0_s.c, xm_usarte0_s.c
// USARTE0 driver
#include "xm_usarte0_s.h"
// Make  sure that the TX pin is an output in the init sequence
void USARTE0_init(void)
	PORTE_DIR |= (1<<PIN3_bp);		//Set TX pin for output
	USARTE0.BAUDCTRLB = (uint8_t) ((F_CPU / (16UL * baud_USARTE0)) - 1) >>8;	// baud register high
	USARTE0.BAUDCTRLA = (uint8_t) (F_CPU / (16UL * baud_USARTE0)) - 1;			// baud register low
  	USARTE0.CTRLB = (1<<USART_RXEN_bp | 1<<USART_TXEN_bp ); 					// enable receive and transmit
int USARTE0_putchar(char c, FILE *stream)
	while (!(USARTE0.STATUS & (1 << USART_DREIF_bp)));
	USARTE0.DATA = c;
	return 0;
int USARTE0_getchar (FILE *stream)
	while(! (USARTE0.STATUS & (1 << USART_RXCIF_bp)));  // wait for data
	return USARTE0.DATA;
int	USARTE0_unbuffered_getchar(FILE *stream)
	uint8_t c = 0;	//Default return value if no char received
	if (USARTE0.STATUS & (1<<USART_RXCIF_bp))
		c = USARTE0.DATA;
	return c;
And recall that the specific pins used for the USARTS are shown in the Alternate Pin Function of the data sheet.
And just a reminder, there are TWO data sheets for each Xmega, one for the family, and one for the specific uC.
OK all sorted. :) Thanks JS.
OHHH WOW one of my replies has been marked as the solution wink need to celebrate.
