Multiple Bit Manipulation within Single Macro
12 posts / 0 new
I'd like to simplify code that I'm working on by using bit manipulation macros similar to:
#define BIT_MACRO       PORTD |= (1 << 5)
However, I'd like to combine multiple bit manipulations into a single macro:
#define MULTIBIT_MACRO       PORTD |= (1 << 5) && PORTB |= (1 << 2)
From there I'd like to use the Macro in a statement such as:
void Function(void)
    // Turn on multiple bits at once
    MULTIBIT_MACRO;
Is this possible?
Ben
Why would you put && in there? Why not simply:
#define MULTIBIT_MACRO       PORTD |= (1 << 5) ; PORTB |= (1 << 2)
In C ';' is the usual statement separator though I guess you could use ',' in this case too?
But why with a macro anyway? Why not a function:
static inline multibit(void) {
    PORTD |= (1 << 5);
    PORTB |= (1 << 2);
int main(void) {
    multibit();
The "call" in main() will almost certainly generate two inlined opcodes:
SBI PORTD, 5
SBI PORTB, 2
which is about as efficient as it gets.
By making the function "static inline" you are saying "I don't need a callable copy that might be called from another file - the only use is in this file and I'd like you to just put the code inline not do a CALL/RET to this". In fact this is the only occasion on which you can put such "code" into a header file. Of itself it will not generate any code but any places multibit() is "called" the two SBI's will be generated.
Confusing 'C' with the MS command line?
So not just multiple bits - but multiple bits in multiple ports!?
Ah, excellent suggestion clawson.
One question, however:  Would the macro be less overhead intensive versus using a static inline function, as there is still a function call?
As you can tell I'm very rusty.  It seems when I get a chance to get into electronics projects, I get pulled away from them again for a long bit.
You can make macros as complicated as you like.    Multi-line macros are fiddly to type.    The backslash must be the last character on a line.
I try to put multiple statements on a single line with braces.
With any macro,   you must write very carefully.    Extra parentheses can keep expansions 'safe'.
As Cliff has suggested.    The GCC inline function behaves almost like a macro but with type checking.    And you don't get the backslash problem.
OTOH,   inline functions are not handled as well by all Compilers.    Sometimes a macro does a better job.
Oh,   your use of && looks misplaced.    It does have a use in logical expressions.
Thanks all for the input, quick responses and to the point.
Proof if proof were needed:
$ cat avr.c
    PORTD |= (1 << 5);
    PORTB |= (1 << 2);
int main(void) {
    multibit();
$ avr-gcc -g -Os -mmcu=atmega16 avr.c -o avr.elf
$ avr-objdump -S avr.elf
avr.elf:     file format elf32-avr
Disassembly of section .text:
00000000 <__vectors>:
   0:	0c 94 2a 00 	jmp	0x54	; 0x54 <__ctors_end>
   4:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
   8:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
   c:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  10:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  14:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  18:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  1c:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  20:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  24:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  28:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  2c:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  30:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  34:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  38:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  3c:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  40:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  44:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  48:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  4c:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
  50:	0c 94 34 00 	jmp	0x68	; 0x68 <__bad_interrupt>
00000054 <__ctors_end>:
  54:	11 24       	eor	r1, r1
  56:	1f be       	out	0x3f, r1	; 63
  58:	cf e5       	ldi	r28, 0x5F	; 95
  5a:	d4 e0       	ldi	r29, 0x04	; 4
  5c:	de bf       	out	0x3e, r29	; 62
  5e:	cd bf       	out	0x3d, r28	; 61
  60:	0e 94 36 00 	call	0x6c	; 0x6c <main>
  64:	0c 94 39 00 	jmp	0x72	; 0x72 <_exit>
00000068 <__bad_interrupt>:
  68:	0c 94 00 00 	jmp	0	; 0x0 <__vectors>
0000006c <main>:
    PORTD |= (1 << 5);
  6c:	95 9a       	sbi	0x12, 5	; 18
    PORTB |= (1 << 2);
  6e:	c2 9a       	sbi	0x18, 2	; 24
int main(void) {
    multibit();
  70:	08 95       	ret
00000072 <_exit>:
  72:	f8 94       	cli
00000074 <__stop_program>:
  74:	ff cf       	rjmp	.-2      	; 0x74 <__stop_program>
As you can see (as I confidently predicted) main() consists of two SBIs and a RET and that is all. There is no "overhead" here.
$ cat avr.c
    PORTD |= (1 << 5);
    PORTB |= (1 << 2);
int main(void) {
    multibit();
0000006c <main>:
    PORTD |= (1 << 5);
    PORTB |= (1 << 2);
int main(void) {
    multibit();
  70:	08 95       	ret
00000072 <_exit>:
  72:	f8 94       	cli
Duly noted.  Thanks for sharing this.  Calling a function instead of a macro is better form in this case it seems, anyhow.
Why would you say that?
Steve A.
For one thing, a lot of people find the semantics of function call a lot less interesting than that of macro use.
For one thing, with function call one can see the number of times each argument is evaluated.
Actually, I read that wrong. I thought that the OP was saying that a macro was better form.
Steve A.
