What at the meaning of the file icons in Solution Explorer
2 posts / 0 new
I can't find an answer to this in the help system, what do the different file icons mean in the solution explorer?
With reference to the picture attached, what do the different icons for flow.c and main.c mean?
I think this is a standard Visual Studio thing - so try including that in your searching...
Sadly, the VAssistX documentation is sloppily incomplete, eg:
Icons
Icons in a results window describe its references, including (sic):
  •  definition or declaration
  •  modified / used on the left side of an expression
  •  not modified / used on the right side of an expression
http://docs.wholetomato.com/defa...
I couldn't find anywhere that gives a complete reference.
angry
