How to check the size of each interrupt vector entry?
4 posts / 0 new
I'm trying to write code that does some manipulation of interrupt vectors. What preprocessor macros can I use to check if my vector table uses 16 bit RJMPs (like ATtinys) or 32 bit JMPs (like ATmega2560)?
Haven't had AS up in a while but Isn't that information in the list file?
Happy Trails,
Mike
JaxCoder.com
mike32217 wrote:
the list file
I want it as a preprocessor macro, so I can code both behaviours into the same code.
Would it be reliable to check if FLASHEND is larger than what can be targeted by 12 bits?
Heh.  I had recently started a similar discussion.   https://www.avrfreaks.net/forum/i...
Short answer: use the __AVR_HAVE_JMP_CALL__ symbol defined by the compiler.
