What does this statement mean...
8 posts / 0 new
Hi
This is a statement from some accelerometer code in the EVK1101 fromAtmel ASF
I am running the example code and I can see that it is to display the angle (that the board is held at)
But I am not quite sure about the syntax of this statement:
  if( 0!=(res=is_acc_abs_angle_x(60)) ) angle.x = 60;
In particular if (0!=  .... I have not seen before
thanks
all
Russell
1. the return value from is_acc_abs_angle_x()is assigned to res
2. if res ( and the return value), does not equal zero  (!= 0 )
    then assign 60 to angle.x
Keith Vasilakes
Firmware engineer
Minnesota
Thanks for the quick reply
Russell
Well, '0' is just zero; and you must be familiar with "!=" as the "is not equal to" operator - surely?
I guess you're more used to seeing it as:
  if( (res=is_acc_abs_angle_x(60)) != 0 ) angle.x = 60;
But, clearly A != B is exactly equivalent to B != A - the order is unimportant
So why do people do it "backwards"?
The reason is that it is a very common mistake to write
  if( something = 5 )
when
  if( something == 5 )
is required.
The trouble is that it is perfectly valid 'C'; so compiles without error - but doesn't do what you wanted.
By writing it "backwards", we get
  if( 5 == something )
And accidentally substituting '=' for '==' is then not valid:
  if( 5 = something )
Of course, the problem never arises with "!=" - so it's done there just to be consistent.
http://c-faq.com/style/revtest.html
But embedding the assignment inside the 'if' clause is entirely pointless.
There is absolutely no advantage whatsoever over writing
res = is_acc_abs_angle_x(60);
if( 0!= res ) angle.x = 60;
agree with that!
And I think it's worse than pointless as it's confusing.
Confusing is bad
Keith Vasilakes
Firmware engineer
Minnesota
I agree - and there are further reasons why it's worse than pointless:
  • It makes the expression unnecessarily complex.
    Unnecessary complexity is bad.
  • It makes it harder to debug, as the res value is harder (or impossible) to access.
    Difficult-to-debug is bad.
Hi Gentlemen,
I've never seen this formula using in an 'if' statement before, but many times in while().
Anyway +1 to should be avoided.
BR,
M
