12 channel interrupt based ADC for atmega32u4 processor
9 posts / 0 new
Dear Experts,
for a project I need to get all 12 ADC channels of an ATMEGA32U4 based board to work concurrently.
But I would like to know following answers :
1. what is the maximum frequency sampling for each channel? ( suppose input clock of board is 16MHz).
2. Is there any interrupt based open source code that i can use?
BR
Mehrdad,
The 32u4 has a single channel ADC with a multiplexer in front of it.  you cannot sample all the channels at the same time.
The datasheet has all the sampling information
You get an a/d reading every 100usec or so, so 12 of them will take 1200usecs. What rate do you need?
Hi again,
and thanks for the answer,
Dear Jim,
By concurrent I mean I would like to make all 12 channels work.
I get one sample from first channel and one sample from second channel and ... and loop it again.
Dear Bob,
I need maximum speed of 1000 samples per second for each channel now. ( for ECG project).
But could some body give me a hint how to develop intterupt based 12 channel ADC program?
BR
Mehrdad,
What is the source of the interrupt?  The ADC upon completion of a conversion?
Code would be simple enough.
Set up a counter to count from 0 to 0x0b(11)
mux channel = count
Set up the ADC for interrupt on conversion complete
Start the conversion
Sit in a loop until interrrupt fires
When interrupt fires save the result from the ADC in SRAM
Increment count
mux = count
start ADC
return
I did not include anything for noise reduction etc.  my example is crude to say the least.  Do a search in the forums.  There is something there.
Should be do-able. For max 10bit resolution the ADCs can do a maximum of 15,300 conversions per second. You look like you need 12,000 per second.
Once you get these 12000 samples each second (using 10% to 20% of processor), where are you going to put them on an AVR8?  How much processing is needed and how often?  As you mentioned a USB-enabled AVR model, I'd guess you plan to send stuff out via the USB.  Lessee-- I guess that I'd put all 12 samples into a packet, 25 bytes plus overhead.  Isn't USB once-a-millisecond?  So it would "just work" if you >>never<< were too busy on the other end to swallow a packet?
From previous work and discussions here, each channel had better have very good "drive" to avoid cross-channel effects.
Now, I'm not an expert Xmega user, but round-robin conversions and DMA buffers and inbuilt USB sounds like it was made for this.
Thanks again for answers,
I think for every channel we could get more than 15000 samples per second not for all the channels.
But as I work on LUFA project, I would rather find some peace of code for interrupt based ADC conversion to put inside it.
I dont know how to define interrupt routines for LUFA project uder linux avr compiler yet .
Now I am going to surf the web to find some thing useful.
BR
Mehrdad,
