How to Debug Bootloaded code--AVR Studio 6.2 & AVR Dragon
3 posts / 0 new
The Atmel solution builds the bootloader.  It has access to the source files used to build the bootloader itself.
The bootloader code receives data to loade the application binary over a communication interface, in my case, wireless.  Can I somehow add files and/or configure Studio 6.2 so I can source level debug not only the bootloader code, but also the application?
Or, do I need to debug the application separately?
In practice,   you treat the bootloader as an independent program.     Assuming that you only use it for uploading complete applications.
When you want to debug a regular application,   remove the bootloader and BOOTRST,  then let the Dragon do the uploading.
I really would not attempt to debug both operations at once.     For a start,   you tend to build them as independent programs.
Yes,   you can debug the bootloader if you need to.      Personally,    I would only use a proven bootloader in the first place.
After the debug and testing phase,    it is convenient to burn bootloader+app in one go especially for production.
I used to single-step through code. Twenty years ago.
Now, design before coding eliminates this.
