AVRDude + Dragon doesn't work
5 posts / 0 new
Hi
I try to use AVRDude to program mega48 in debugWire mode on Windows machine. It does not work.
The command line looks like
avrdude -pm48 -cdragon_dw -Uflash:w:GPI.hex:a
The error is:
avrdude: ser_open(): can't open device "lpt1": The system cannot find the file specified.
avrdude from winavr 2100110. I do not understand why avrdude is trying to open lpt1? What port have to be specified to get it working?
I do not use a Dragon. But since it is a USB device, I should add '-P usb'
You normally use separate arguments:
avrdude -p m48 -c dragon_dw -U flash:w:GPI.hex:a
Otherwise you may end up with a msdos argument abortion.
Edit. I have just tried the 'no space' method. It parses fine. It just looks wrong to me.
This is what I use in the CodeVision Tools Menu:
avdrude.exe -c jtag2dw -P usb -p t2313 -U flash:w:"#h":i -v
N.b. # should be a %
I did try with many -P USB variations and I end up with "it can't open device "USB".
I'm not sure usb must be specified, for example usbtiny uasbasp programmers works fine without any port specified.
Well, the JTAGICEmkII works fine with avrdude. Remember that a special feature of avrdude is that it uses a different USB driver to Atmel.
So jtagicemkii.exe works out of the box with Atmel's Jungo driver.
avrdude -c jtag2 -P usb only works when you have installed libusb.dll
I do not know what avrdude -c usbtiny uses. I would assume libusb.dll but it may bit-bash things since it is only USBv1.0
Use the COM port after -P
