Simple blink program won't run from Atmel Studio 6
6 posts / 0 new
I am slowly moving from Arduino to AVR C. I purchased an atmega32u4 breakout board from Adafruit (this one here) which comes preloaded with a bootloader that allows programming through the USB interface. I setup Atmel Studio 6 to write and build the code and avrdude to upload the hex file onto the micro controller. These steps work well and I am able to build and upload without issue. The problem I am having is that the hex file built by Atmel Studio does not appear to run on the mega32:
#ifndef F_CPU
#define F_CPU 16000000L // 16 MHz clock speed
#endif
#include <util/delay.h>
   DDRC = 0xFF; //Makes all pins on PORTC outputs
   while(1) //infinite loop
      PORTC = 0xFF;
      _delay_ms(1000); //1 second delay
      PORTC = 0x00;
There is a simple circuit of a LED and a resistor to verify the operation of the code above.
I have taken the same code above and put it into the Arduino IDE as such:
void setup()
  DDRC = 0xFF;
void loop()
   PORTC = 0xFF;
   _delay_ms(1000);
   PORTC = 0x00;
   _delay_ms(1000);
This works as expected and the LED lights on and off at about once per second. I am using the Arduino IDE only to build the hex file using the Leonardo profile (runs an atmega32u4). However, in both cases I am using avrdude to upload the hex file to the micro controller as such:
avrdude.exe -F -v -c avr109 -p m32u4 -U flash:w:Blinky.hex:i -P COM5
I have a high degree of confidence I am doing something wrong in Atmel Studio.
Thanks for listening.
I have a high degree of confidence that you are using the -F flag in avrdude.  Never override the invalid signature check.  Post the output of avrdude command:
avrdude.exe -vv -c avr109 -p m32u4 -U flash:w:Blinky.hex:i -P COM5
Have you selected the right device in Atmel Studio?
EDIT:
On what Port and Pin?  You are toggling all the Pins on the PORT.   Try that on PORTB instead.  Hint: Look at the data sheet to see how many pins you have available on PORTC.
I started by calling out a single pin (PC6) on PORTC in code. That is where the LED is plugged into. I switched the code to toggle the entire port because I wanted to make sure it was not me using the wrong pin ID.
I moved the LED to PB4 and switched the code accordingly:
    DDRB = 0xFF;// |= _BV(PC5); // output
        //TODO:: Please write your application code
		PORTB = 0xFF;//|= _BV(PC6);
		_delay_ms(1000);
		PORTB = 0x00; //&= ~(_BV(PC6));
		_delay_ms(1000);
I've put the LED on all the PB* pins available and still no joy from the Atmel Studio hex. I did also remove the -F flag from avrdude:
avrdude.exe: Version 5.10, compiled on Jan 19 2010 at 10:45:23
             Copyright (c) 2007-2009 Joerg Wunsch
             System wide configuration file is "C:\Program Files (x86)\WinAVR\bin\avrdude.conf"
             Using Port                    : COM5
             Using Programmer              : avr109
             avr910_devcode (avrdude.conf) : none
             AVR Part                      : ATmega32U4
             Chip Erase delay              : 9000 us
             PAGEL                         : PD7
             BS2                           : PA0
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             serial program mode           : yes
             parallel program mode         : yes
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
                                      Block Poll               Page                       Polled
               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
               eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
               lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Programmer Type : avr910
             Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "LUFACDC"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude.exe: devcode selected: 0x44
avrdude.exe: AVR device initialized and ready to accept instructions
avrdude.exe: Device signature = 0x1e9587
avrdude.exe: safemode: lfuse reads as FC
avrdude.exe: safemode: hfuse reads as D0
avrdude.exe: safemode: efuse reads as C3
avrdude.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed
avrdude.exe: erasing chip
avrdude.exe: reading input file "C:\Users\mquezada\Documents\Atmel Studio\6.2\Blinky\Blinky\Debug\Blinky.hex"
avrdude.exe: writing flash (158 bytes):
Writing | ################################################## | 100% 0.02s
avrdude.exe: 158 bytes of flash written
avrdude.exe: verifying flash memory against C:\Users\mquezada\Documents\Atmel Studio\6.2\Blinky\Blinky\Debug\Blinky.hex:
avrdude.exe: load data flash data from input file C:\Users\mquezada\Documents\Atmel Studio\6.2\Blinky\Blinky\Debug\Blinky.hex:
avrdude.exe: input file C:\Users\mquezada\Documents\Atmel Studio\6.2\Blinky\Blinky\Debug\Blinky.hex contains 158 bytes
avrdude.exe: reading on-chip flash data:
avrdude.exe: verifying ...
avrdude.exe: 158 bytes of flash verified
avrdude.exe: safemode: Fuses OK
avrdude.exe done.  Thank you.
I also uploaded this version using the Arduino IDE. The only difference I notice between avrdude outputs is the field called StabDelay. Uploading the Arduino hex it says 150 instead of 100 from the Atmel Studio hex.
This works fine on my atmega32u4 breakout board from Adafruit
 * CapacitiveSmokeBlinky.c
 * Created: 3/14/2015 10:35:12 AM
 *  Author: Larry
 DDRB = 0xFF;
  PORTB = 0xFF;
  _delay_ms(1000);
  PORTB = 0x00;
  _delay_ms(1000);
OK, I'll check it out as soon I get back to the bench. I see the CPU speed definition is after the io.h include and before delay.h. This gives me hope and frustration :). Would you mind sharing your fuse settings? Just in case.
In Atmel Studio I selected Atmega32 as the device.
Nevermind, I figured it out. I was following a tutorial and it said to load the Atmega32 device in Atmel Studio, so I did..... I looked further into the datasheet and realized that was not the device I have and indeed an Atmega32U4 device is further down the list. Go figure now it works.
Larry, I am sorry I wasted your time, I do appreciate you taking a look at it to try to help me out.
