Unexpected integer cast warning on register
4 posts / 0 new
So, I've got a pointer in an timer CTC interrupt ISR(TIMER0_COMPA_vect)
static const unsigned char *timing_pointer = brightness_timings;
pointing to a constant array of chars
const unsigned char brightness_timings[MAX_BRIGHTNESS+1] = {blah blah blah}
and I'm setting OCR0A (compare register for timer 0, an 8-bit register) during its interrupt:
	OCR0A = timing_pointer++;
When I compile with avr-gcc (4.8.2) I get this warning for that instruction:
assignment makes integer from pointer without a cast
I don't see any integers anywhere... can anyone tell me why this is happening?
surely you mean
OCR0A = *timing_pointer++;
You want something out of the array - not the address of the data - so you need a pointer dereference.
Hope he didn't mean smiley:
  OCR0A = (*timing_pointer)++;
Edit: But unlikely with const pointer
Computers don't make errors - What they do they do on purpose.
clawson wrote:
surely you mean
Ah... that'll be it. Thanks!
