this program is correct ?
12 posts / 0 new
Do
   Waitms 500
   Kb = Getkbd()
   Kb = Lookup(kb , Equal)
   If Kb = 12 Then Goto Number
            Z = Getadc(0) : Z = Z / 2
Locate 1 , 1 : Lcd "temp is:" ; Z ; "c"
Locate 2 , 1
Lcd Time$
Waitms 500
   W = Getadc(1)
Loop Until W > 300
Cls
Lcd "Alarm"
Set Alarm
getadc0 = lm35
and getadc1 is mq5 ...the loops are correct ?!
my english isnt good !! use easy words pls !!
I am not a native Chinese speaker, but code is MUCH easier to read if you use indentation. e.g. you line up blocks of code nicely.
Do
    foo
Loop Until bar
You will generally see for yourself if you have a problem with your logic.
It is also helpful to you, if you add a few comments.
no i want to understand that this program have any problem ??
because i cant get answar in circuit with this program
Your main loop ends with
 Loop Until W > 300
And I do not like "If Kb = 12 Then Goto Number".
Are you not returning to main?
The code should probably be
   Do
      Waitms 500
      Kb = Getkbd()
      If Kb = 12 Then Goto Number       '??
      Locate 2 , 1
      Lcd Time$
      Waitms 500
         Do
            W = Getadc(1)
         Loop Until W > 300
      Cls
      Lcd "Alarm"
      Set Alarm
   Loop
End
no this program have continu . number isnt important ! it is for get number from keypad
so see this ...i think i cant use your loops !
Main:
Reset Alarm
Reset Connect
S = Es
Cls
Do
   Waitms 500
   Kb = Getkbd()
Locate 2 , 1
Lcd Time$
Waitms 500
   W = Getadc(1)
Loop Until W > 300
Cls
Lcd "Alarm"
Set Alarm
Do
   W = Getadc(1)
   B = W / 1024
   A = B * 100
   Lowerline
   Lcd A ; "%   "
   If W < 300 Then Goto Main
Loop Until W > 600
Cls
Lcd "Dialing..."
Lowerline
Lcd S
Set Connect
Wait 1
Dtmfout S , 200
Wait 15
Goto Main
If runs correctly then probably is.If you have any doubts just compile and then simulate it.
so the post 6 : 31 pm is ok ?
hi excuse me comment on your post
i want to convert output of mq9 to ppm
i read the datasheet,but the datasheet just had a figure based on Rs/Ro and ppm
how can i convert the adc_data of output sensor to ppm?
please help me
tnx all
Mohammad,
In the future please use the "New Post" button to start a new topic, (new Thread), in the Forum.
This Thread is 5 years old, and people don't want to read through it to find your new question at the bottom.
To answer your question more info is needed.
What language?
What microcontroller?
What is mq9
How much experience do you have with the language and with microcontrollers?
What have you tried so far?
ok sure
What is mq9
An unmanned aerial vehicle?
http://en.wikipedia.org/wiki/Gen...
But given the context, probably more like
http://www.dfrobot.com/image/dat...
Think about your question for a moment.  It is like asking "how long is a piece of string?"  Don't you think, for example, that the answer will be different if the ADC reference voltage is 1V or 3V or 5V?   And many other factors such as that.
Lots of pertinent hits on the first page of results
http://www.lmgtfy.com/?q=mq9+avr...
