Is there a command that can execute a loop until a certain bit is set ???
27 posts / 0 new
Hello everybody. I'm just a newbie to AVR and I'm very interested in AVR. So I'm doing a simple circuit with ATMEGA 8 that blinks from LED 1 to 8 and then goes back to LED 1
I wrote a simple code like this and it works just fine
 while(1){
            for (int i=0;i<7;i++){
			PORTB=val;
            _delay_loop_2(65000);
            val*=2;
			PORTB=val;
			val=val/2;
but I was wondering if there is anyway to make this shorter, like is there some sort of command that loops only until a certain bit connecting to a certain LED is set ??
In my situation, said bits are PB0 and PB7. I attached a screenshot of my project in Proteus.
Please help me, I will be much appreciated
And forgive me for my English
Think about what you are asking, does it make sense?
You are setting the bits that control the LEDs in the loops.  You are not reading those bits, and even if you were what purpose would it have?
Why do you want it shorter? And shorter in what sense? I would first try to make it more readable with proper indentation, then be happy with that (well I'd probably replace _delay_loop_2 with _delay_ms).
You mean like a while statement?
Without adult supervision.
#define F_CPU 8000000UL
#include <util/delay.h>
    DDRB = 0xFF;
        for (uint8_t i = 0; i < 7; i++)
            PORTB = (1 << i);
            _delay_ms(500);
        for (uint8_t i = 7; i > 0; i--)
            PORTB = (1 << i);
            _delay_ms(500);
If OP indeed wants to get down to the cycle, isn't the underlying "delay cycles" upon which the modern GCC _delay_XX() are built?
__builtin_avr_delay_cycles(unsigned long)
https://gcc.gnu.org/onlinedocs/g...
Larry, the first for() loop should be less than 8 instead of 7. 2nd for(), <= 0.
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
http://www.nongnu.org/avr-libc/user-manual/group__util__delay.html
https://gcc.gnu.org/onlinedocs/gcc-4.7.1/gcc/AVR-Built_002din-Functions.html
Well yes, if someone really wants an exact number of cycles as delay, and maybe that's the case here, I don't know.
Actually I was going to suggest in another thread, where someone wanted an exact delay in C without util/delay.h
#define delay_ms(x) __builtin_avr_delay_cycles(F_CPU * (x) / 1000)
(untested) but I didn't.
No, the first loop hits bits 0 through 6, the second loop hits bit 7 through 1, no overlap on bits 0 and 7.
Besides, I like it the way I wrote it.smiley
I'm not going to make many change in your code(because I'm not sure what you have asked us) but I think you want a code like this:
while(1){
            for ( int i=0 ; i<16 ; i++ ){
				PORTB = val;
				if( i<8 ){
					val *= 2;
				} else{
					val = val/2;
is it right?
"One's value is inherent; money is not inherent"
Chuck, you are in my heart!
I offer an alternative
enum { false = 0, true };
typedef unsigned char bool;
	DDRB = 0xFF;
	volatile uint8_t mask = 1;
	volatile bool dirUp = true;
			PORTB = mask;;
			_delay_ms(500);
			if (dirUp)
				mask <<= 1;
				mask >>= 1;
		dirUp = !dirUp;
Happy Trails,
Mike
JaxCoder.com
Mine's less elegant. cheeky
larryvc wrote:
Mine's shorter. cheeky
Hmmm, How bout now?  devil
	DDRB = 0xFF;
		for (uint8_t i = 0; i < 7; i++, PORTB = mask)
			_delay_ms(500);
			(dirUp) ? (mask <<= 1) : (mask >>= 1);
		dirUp = !dirUp;
Happy Trails,
Mike
JaxCoder.com
Total votes: 2
  I was lying before.wink
But don't use the bool, the enum, or the volatiles.  It is more efficient and shorter without them.
#define DDR DDRB
#define PORT PORTB
#define delay 500
 DDR = 0xFF;
 uint8_t mask = 1, dirUp = 1;
  for (uint8_t i = 0; i < 7; i++, PORT = mask)
   _delay_ms(delay);
  dirUp = !dirUp;
Weighs in at 300 bytes with -Os optimization.
I think the OP should be quite happy with all of these examples.
thanks everybody for replying. And I apologized for my English since I could not make my question more understandable for you guys.
I did some research yesterday and found out the macro bit_is_clear
unsigned char val=1;
int main(void){
      DDRB=0xFF; //set PORTB as output lines
      while(1){
            while(bit_is_clear(PINB,7)){
			PORTB=val;
            val*=2;
            while(bit_is_clear(PINB,0))
			PORTB=val;
			val=val/2;
      return 0;
can I use the macro like this for the code ?
Here's one I wrote a couple of years ago:
    uint8_t d = 0, i = 0;
    DDRB = 0xFF;
    while (1) {
	if (!(i = d ? i>>1 : i<<1))
	    i = (d = !d) ? 0x40 : 2;
	PORTB = i;
	_delay_ms(100);
    return 0;
devil
Why don't you try it? You have to test the bits in PORTB or val, not PINB.
#define DDR DDRB
#define PORT PORTB
#define delay 500
 DDR = 0xFF;
   _delay_ms(delay);
  dirUp = !dirUp;
Larryvc,
Yours was a very elegant and simple solution I was just trying to show the OP that there is more than one way to do things when programming.
The voices in my head made me do it. wink
Happy Trails,
Mike
JaxCoder.com
Probably the same voices I hear.
snigelen wrote:
Here's one I wrote a couple of years ago:devil
Show off!wink
Yes, but it really is not a very good way to control the for loops.  Please take the time to look at the other examples that were given.  You can learn a lot from studying code written by others.
Here is a working version modeled on what I see as your vision for the program.  You need to define val as an integer and there are some changes that need to be made to the code.  Also note that the LEDs on PORTB pins 0 and 7 will be on for 1000ms after the first time through the first loop whereas the other LEDs will only be on for 500ms.
#define delay 500
    DDRB = 0xFF; //set PORT pins to outputs
        int val = 1;
            PORTB = val;
            _delay_ms(delay);
            val *= 2;
        // val is now = 256 so divide first
            val /= 2;
            PORTB = val;
            _delay_ms(delay);
thank you mr.Larry for replying. I really appreciate your help
I have one more problem. I just read a code which is used to print the number 4 on a dot matrix 7x5
#include<avr/io.h>
#include<font.h>
#include<util/delay.h>
void led(uint8_t chr){
	uint8_t line=1;
	uint16_t temp=chr;
	for (int i=0;i<=4;i++)
	PORTC=line;
	PORTD=~pgm_read_byte(&font7x5[(temp-32)*5+i]);
	line<<=1;
	_delay_loop_2(1000);
int main(void){
	DDRD=0xFF;
	DDRC=0xFF;
	led('4');
	return 0;
I decided to try making it display the number from 0 to 9 so I changed the code a bit
	for (int j=0;i<=9;j++){
	led('j');
	_delay_ms(100);
but it just shows the letter j on the matrix. Can you please tell me how to fix this ?
Try
	for (char j='0';i<='9';j++){
	  led(j);
	  _delay_ms(100);
EDIT: to change int to char.
led('j');
Isn't
led(j);
And also j is integer you should convert it to char.
dude, I think you should review a C book.
Pokemon.master,
I highly recommend you reading the classic K&R C to get a better grasp of the language.
Also learning some good debugging techniques would be useful.
If you keep asking basic question and just looking for answers people will get tired of it and will quit responding.
Happy Trails,
Mike
JaxCoder.com
thanks everybody. And I really apologize for my lack of knowledge.
thanks Mr.Mike, I'll try to read your book
Another example for pokemon.master to study:
#define DDR DDRB
#define PIN PINB
#define PORT PORTB
#define delay 500
    DDR = 0xFF;
        uint8_t led;
        for (uint8_t i = 0; i < 14; i++)
            if (i & 8)
                (led = (14 - i));
                (led = i);
            PORT = (1 << led);
            _delay_ms(delay);
I think tha OP was originally asking for something like this:
    while(1) {
        for(uint8_t mask=1; mask; mask<<=1} {
            PORTB=mask;
            _delay_ms(1000);
        } // mask
        for(uint8_t mask=0x40; !(mask & 1); mask>>=1) {
            PORTB=mask;
            _delay_ms(1000);
        } // mask
    } // forever
If one really wants cute:
    for(uint8_t mask=1, up=0;  ; mask=mask<<up>>!up) {
        PORB=mask;
        _delay_ms(1000);
        up^=!!(mask & 0x81);
    } // mask, up
} // main
