TWI or I2C : I don't understand how to use the TWINT flag
6 posts / 0 new
I am learning how to use TWI (I²C) by reading the documentation and tutorials on the Internet. I have a little problem about how the TWINT flag in the TWSR register is used.
Let's talk about the basics : send a START condition. To do it, as the documentation says:
TWEN must be set to enable the 2-wire Serial Interface, TWSTA must be written to one to transmit a START
condition and TWINT must be written to one to clear the TWINT Flag.
Ok. So I write those 3 bits to one : TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
My TWSR register is now : 10100100b (the MSB is TWINT).
What I understand is that we clear the TWINT Flag by setting it to 1. So TWINT is a 1.
Then, we need to wait that the START condition has been sent. For that, as it is write in the documentation :
After a START condition has been transmitted, the TWINT Flag is set by hardware.
OK, so I need to wait for the TWINT Flag to be set, so equal to 0.
To do that, what I would do would be to code a while condition like it: while(TWINT FLAG is equal to 1);
For me, I write it like this : while(TWSR & (1<<TWINT));
BUT, EVERYWERE ON THE INTERNET I FIND : while(!(TWSR & (1<<TWINT)));
Even on the AVR documentation.
I am on it for hours, maybe that I am missing the obvious... Why does everybody check the opposite?
Thank you. :)
"set" in my dialect means "1" not "0".
Sure it is possibly "odd" that to clear flags you write 1 (but there's a good reason for that) but the flag itself is "the right way up". It is 0 when the interrupt hasn't occurred and changes to 1 when it does occur. A short time later the CPU opcode fetching mechanism will notice this change and then vector to ISR handler (if its been enabled).
As for clearing the flag. If it is 1 saying "the interrupt recently occurred" and you write 1 to it that actually sets it back to 0. This is where the "odd" bit comes in.
OK so I understand that if I write a 1 to TWINT, then TWINT will become 0. TWINT takes the oposite value of what you write to it. Right ? That would explain why I don't understand...
It has been a common practice for decades by micros manufacturers to write a 1 to register bits in order to clear them, not Atmel specific.
Setting bits to 0 generally involves IN/AND/OUT to isolate only the bits to be changed. Whereas using 1 bits you can do it in a single write (which is therefore atomic).
No.  Writing '1' will cause the flag to be cleared.  Writing '0' does nothing at all.
