24bit counter on ATMEGA103
4 posts / 0 new
I use the ATMEGA103 MCU and need a 24bit counter.
Standard the 'biggest' counter has 16 bits.
What could be the best way (if there is any) to make a 24 bit counter ?
Thank you for your response,
Carlo Veld
Hey Carlo,
Setup up the 16-bit counter overflow interrupt routine. In the routine just increment an 8-bit register. If you need to make a 24-bit counter overflow routine then just change the routine to be
if( 8bitregister == $FFFF )
do the overflow code
8bitregister++;
This should work pretty well and with accuracy. If you need to reset the counter just make sure to reset the 8-bit register!!!
admin's test signature
Hey Ian,
Thank you for your quick response and usefull help.
Now I can try to implement this solution in C++.
You may want to try cascading the counters where you use the overflow output of one, as the input of the second counter.
You would have to be careful during a counter clear, but that should allow you to use the two counters as a single wider counter.
