bug? or am i wrong?
3 posts / 0 new
hello,
i'm learning C from the book from smileymicros.
it's getting along, but now i have an error i can't figure out.
this is the code (partial)
int ADC_read(void)
char i;
int ADC_temp = 0;
int ADCr = 0;
// do a dummy read first
ADCSRA |= (1<<ADSC); // do a single conversion
// wait for conversion done
while (!(ADCSRA && 0x40));
// do the ADC conversion 8 times
for (i=0; i<8; i++)
ADC_temp = ADCL; // read out ADCL register
ADC_temp += (ADCH << 8 ); // read out ADCH register
//accumulate for later averaging
ADCr += ADC_temp;
sendChar('B'); //*************ERROR
ADCr = ADCr >> 3; //average the 8 samples
ADCSRA = (0<<ADEN); //disable the ADC
return ADCr;
// routine 2***********************************
void getAbs()
int ADCresult = 0;
char abso[] = {'0','0','0','\0'};
ADC_init(7);
ADCresult = ADC_read();
// sendChar(ADCresult);
itoa(ADCresult, abso, 10);
sendString ("\r the value is: ");
sendString (abso);
//end code***********************************
the routine getAbs() calls ADC_read
how it is posted it works, but if i delete the line
the ADC_read function always returns 0 ????
if i use sendChar(ADCr) instead of ('B') i get the correct value from the ADC, but the function returns 0 :-(
So far i found al the errors (until page 217, not bad?) but i don't get it now.
Please help???
I've used the WINAVR 20050214 & and 200404 (as recomended by smileymicros)
This is incorrect, since it will not wait for the conversion to complete. Try:
 while (ADCSRA & (1 << ADSC)) /*EMPTY*/;
This would explain getting 0-s back from the ADC, but not why
calling sendChar() -- presumably introducing a delay, but only after you're
finished the conversions -- would "fix" the problem.
Anyway, fix this line (both places) and see if it looks different.
thanks, this solves the problem.
The delay invoked by sendChar was indeed the reason it worked, because a
_delay_loop_1(20);
worked also...
Still don't know why this delay then solved the problem...
