AVR32 exception.x hacking
3 posts / 0 new
Atmel use this assembly code:
.balign 4
.irp priority,0,1,2,3
_int\priority:
  mov r12, \priority
  call _get_interrupt_handler
  cp.w r12, 0
  movne pc, r12
  rete
.endr
I hack it this way:
.balign 4
.irp priority,0,1,2
_int\priority:
  mov r12, \priority
  cp.w r12, 0
  movne pc, r12
  rete
.endr
.balign 4
_int3:
  mov r12, _lo_pwm_isr_handler
  orh r12, _hi_pwm_isr_handler
  mov pc, r12
It is simple and stupid - but it works !
You can have only ONE isr with highest priority, but it is OK for me.
One sidenote: avr-gcc don't complain about global C variable, but I can't get correct value this way. Finaly I have to set immidiate values, but who cares - it works !
QUESTION: anybody knows why avr-gcc did not put correct values for global C variables here ?
I declare C variables _lo_pwm_isr_handler and _hi_pwm_isr_handler in intc.h file:
unsigned short _lo_pwm_isr_handler;
unsigned short _hi_pwm_isr_handler;
I set value in INTC_register_interrupt in intc.c file this way:
if (int_level == 3)
  _lo_pwm_isr_handler = ((unsigned long) handler & 0xFFFF);
  _hi_pwm_isr_handler = ((unsigned long) handler >> 16);
Final note:
As I wrote in second post, you can use C variable to get ISR handler. But remember what is our goal - to be fast as possible. It is worth to repeat FASTEST solution - use immediate values:
.balign 4
_int3:
  mov r12, 0xC010     // lo part of handler address
  orh r12, 0x8001     // hi part
  mov pc, r12
ok - now I understand what is going on.
I can use C variables in assembly. but I have to know some basic. First of all, MOV command is for load IMMIDIATE values only. So - this one will not work:
Here is solution:
    mov     r12, 0
    ld.w    r12, r12[_pwm_isr_handler]
    cp.w    r12, 0
    movne   pc, r12
    rete
one more thing. This one is not trivial at all. If I don't have mkII debuger I will never find what is going on. This command fire _handle_Data_Address_Read: exception
and default handler for all exceptions are infinite loop - bad luck ! so - I have to change default behaviour, like this:
     .org  0x034
        // Data Address (Read).
		rete
        // rjmp $
and that's it !
regards to all - merry hacking !
Kepica,
It looks like you handle the exception using rete instruction.
But is there any way to know why this exception was generated ?
I am getting _handle_bus_error_data_fetch exception when try to use flash on my UC3B0512 chip.
How to know the instruction in C code that causes exception.
Please let me know if there is any way of doing it.
