ILI9341 TFT display controler
6 posts / 0 new
Anybody know if this thing has a low power shut down mode? Perhaps I should provide a PFET to turn the thing off?
In my humble opinion, I'm always right.
Didja look in the datasheet?
Interestingly, I cannot seem to finsd a number for sleep mode current.  Standby is 100uA
Does this command affect the LCD screen backlight LEDs, or only the controller, or both?  Often this TFT controller is found on the 2.2" 320x240 modules (and possibly other inch-board sizes).  It uses Adafruit TFTv2 library.   The SPI versions of this TFT board have an LED pin that *I believe* is internally connected to a transistor that controls the brightness background LED(s).  If this proves to be the case, then using a PWM signal on this pin (LEDBK) would control the screen's power usage if the sleep command only turns off the controller IC.
Anyone here know more about this stuff?
As Lee pointed out it has sleep mode that you can use for your job.
You are right Simonetta BUT:
What do you mean "internally"?
within the IC controller?
or on board?
if on board, there is no transistor. totally you need to control the background LEDs separately.
"One's value is inherent; money is not inherent"
Chuck, you are in my heart!
I could have looked all day and not seen something that obvious
The backlight LEDs, at least on this display, are controlled by the processor, not the ILI chip. I know not why, but that's how this display is built.
It's the same on the display I use, the back-light is not controlled by the controller, I think that it's simply a sandwich: back light , display with controller, and touch.
I can see it on my flex-cable back-light and touch are soldered on to the display tail.
