Hi.
I would like to use C++ in Atmel Studio, so I write code below:
//******Main.CPP******* #define F_CPU 32000000UL #include "Settings.h" #include "ILI9225G.h" int main(void) { Settings st; st.Config32MHzClock(); InitLCDPins(); while(1) { } }
//******Settings.h******** #ifndef __SETTINGS_H__ #define __SETTINGS_H__ class Settings { //variables public: protected: private: //functions public: Settings(); ~Settings(); void Config32MHzClock(); protected: private: Settings( const Settings &c ); Settings& operator=( const Settings &c ); }; //Settings #endif //__SETTINGS_H__
//***** Settings.cpp****** #include "avr_compiler.h" #include "Settings.h" // default constructor Settings::Settings() { } //Settings // default destructor Settings::~Settings() { } //~Settings void Settings::Config32MHzClock() { CCP = CCP_IOREG_gc; //Security Signature to modify clock // initialize clock source to be 32MHz internal oscillator (no PLL) OSC.CTRL = OSC_RC32MEN_bm; // enable internal 32MHz oscillator while(!(OSC.STATUS & OSC_RC32MRDY_bm)); // wait for oscillator ready CCP = CCP_IOREG_gc; //Security Signature to modify clock CLK.CTRL = CLK_SCLKSEL_RC32M_gc; //select sysclock 32MHz osc }
#ifndef ILI9225G_H_ #define ILI9225G_H_ #include "avr_compiler.h" #define LCD_DATA_PORT PORTH #define LCD_CMD_PORT PORTJ void InitLCDPins() { LCD_DATA_PORT.DIR=0xFF; LCD_CMD_PORT.DIR=0xFF; LCD_CMD_PORT.OUT=0xFF; LCD_DATA_PORT.OUT=0xFF; } #endif /* ILI9225G_H_ */
#ifndef COMPILER_AVR_H #define COMPILER_AVR_H #ifndef F_CPU /*! \brief Define default CPU frequency, if this is not already defined. */ #define F_CPU 2000000UL #endif #include <stdint.h> #include <stdbool.h> #include <stdlib.h> #include <string.h> uint8_t volatile saved_sreg; /*! \brief This macro will protect the following code from interrupts. */ #define AVR_ENTER_CRITICAL_REGION( ) saved_sreg = SREG; \ cli(); /*! \brief This macro must always be used in conjunction with AVR_ENTER_CRITICAL_REGION * so the interrupts are enabled again. */ #define AVR_LEAVE_CRITICAL_REGION( ) SREG = saved_sreg; #if defined( __ICCAVR__ ) #include <inavr.h> #include <ioavr.h> #include <intrinsics.h> #include <pgmspace.h> #ifndef __HAS_ELPM__ #define _MEMATTR __flash #else /* __HAS_ELPM__ */ #define _MEMATTR __farflash #endif /* __HAS_ELPM__ */ /*! \brief Perform a delay of \c us microseconds. * * The macro F_CPU is supposed to be defined to a constant defining the CPU * clock frequency (in Hertz). * * The maximal possible delay is 262.14 ms / F_CPU in MHz. * * \note For the IAR compiler, currently F_CPU must be a * multiple of 1000000UL (1 MHz). */ #define delay_us( us ) ( __delay_cycles( ( F_CPU / 1000000UL ) * ( us ) ) ) /*! \brief Preprocessor magic. * * Some preprocessor magic to allow for a header file abstraction of * interrupt service routine declarations for the IAR compiler. This * requires the use of the C99 _Pragma() directive (rather than the * old #pragma one that could not be used as a macro replacement), as * well as two different levels of preprocessor concetanations in * order to do both, assign the correct interrupt vector name, as well * as construct a unique function name for the ISR. * * \note Do *NOT* try to reorder the macros below, as this will only * work in the given order. */ #define PRAGMA(x) _Pragma( #x ) #define ISR(vec) PRAGMA( vector=vec ) __interrupt void handler_##vec(void) #define sei( ) (__enable_interrupt( )) #define cli( ) (__disable_interrupt( )) /*! \brief Define the no operation macro. */ #define nop( ) (__no_operation()) /*! \brief Define the watchdog reset macro. */ #define watchdog_reset( ) (__watchdog_reset( )) #define INLINE PRAGMA( inline=forced ) static #define FLASH_DECLARE(x) _MEMATTR x #define FLASH_STRING(x) ((_MEMATTR const char *)(x)) #define FLASH_STRING_T char const _MEMATTR * #define FLASH_BYTE_ARRAY_T uint8_t const _MEMATTR * #define PGM_READ_BYTE(x) *(x) #define PGM_READ_WORD(x) *(x) #define SHORTENUM /**/ #elif defined( __GNUC__ ) #include <avr/io.h> #include <avr/interrupt.h> #include <avr/pgmspace.h> #include <util/delay.h> /*! \brief Define the delay_us macro for GCC. */ #define delay_us( us ) (_delay_us( us )) #define INLINE static inline /*! \brief Define the no operation macro. */ #define nop() do { __asm__ __volatile__ ("nop"); } while (0) #define MAIN_TASK_PROLOGUE int #define MAIN_TASK_EPILOGUE() return -1; #define SHORTENUM __attribute__ ((packed)) #else #error Compiler not supported. #endif #endif
Atmel Studio show this error:
"Error 1 multiple definition of `saved_sreg' "
which saved_sreg is used in avr_compiler.h
could you please guide me how can I fix this error?
