Connecting microSD card to 2 microcontrollers.
7 posts / 0 new
Good day,
Is is possible to make circuit, which will share microSD card with 2 master devices.
1. I mean I connect microSD card to device number 1.
2. I use that card with device number 1.
3. I disconnect microSD card with device number 1.
4. Now i can connect microSD to device number 2.
... do some stuff with that.
I use SDIO, I need to share DAT0, DAT1, DAT2, DAT3, CLK, CMD lines.
So I need some circuit. I think its possible to do with 6 transistors, 1 transistor for each line.
Maybe its possible to use it with some chip?
Thanks in advance!
//Nikolaj
Something like a 74HCT4052 might be of use. I'm not sure how you'd achieve your goal with 6 transistors.
There are 2 issues here:
  1. The physical connection;
  2. Ensuring that one "host" is completely finished and has fully closed-down and cleaned-up what it was doing before allowing the other host to start.
You only seem to be thinking about No 1 - but I suspect that No 2 will be the harder to crack...
It might be better to have a dedicated "controller" for the SD-Card, and have the others talk to it...
Yea will be challenging if you stick to a physical-layer solution only.  Probably need some controller in middle to do the arbitration.
Option 2: pull-ups for all SD card pins, 'Y' connected to both controllers, with all GPIOs set as open-drain. The Chip enable pin connected to input pins on both controllers to work as a common "Busy" line.
while(!solution) {patience--;}
Two MCUs, one card.
MOSI signals collide.
OP stated SDIO - so not SPI.
However, OP has shown no further interest - so I guess this'll just continue to rattle about as a general discussion...
Oops.
