External interrupt of cuple or more input port is not pssible.
3 posts / 0 new
I use ATxmega64A3U.
I connect two buttons with a ATxmega64A3U of circuit board.
The button No1 is PA3,
The button No2 is PC2,
I perform sleep of a microcomputer until a button is pushed and make a power save mode.
void slave_main(void)
	volatile fifo_t * fifo;
	u8 length=0;
	int i;
	SLEEP_CTRL |= SLEEP_SMODE_PSAVE_gc;
	SLEEP_CTRL |= SLEEP_SEN_bm;
	PORTA.INT1MASK=0x08;		//GDOA PIN
	//PORTA.INT1MASK=0x04;		//GDOA PIN
	PORTA.INTCTRL=0x0c;
	//PORTC.INT0MASK=0x04;		//EMG_Button
	PORTC.INT1MASK=0x04;		//EMG_Button
	//PORTC.INTCTRL=0x03;
	PORTC.INTCTRL=0x08;
		sleep();
		if(interup_state == WAKEUP_DOOR_OPEN)
			for(i=0;i<10;i++)
				set_communication_led(1);
				_delay_ms(1000);
				set_communication_led(0);
				_delay_ms(1000);
		if(interup_state == WAKEUP_EMG_SEND)
			for(i=0;i<10;i++)
				set_bat_led(1);
				_delay_ms(1000);
				set_bat_led(0);
				_delay_ms(1000);
The button of PA3 breaks through at an interrupt routine.
However, the button PC2 does not break through at an interrupt routine at all.
ISR(PORTA_INT1_vect)
	test_cnt++;
	if(~PORTA.IN & 0x08)
		interup_state = WAKEUP_DOOR_OPEN;
	if(~PORTC.IN & 0x04)
		interup_state = WAKEUP_EMG_SEND;
I set the INT1 interrupt with both ports.
I would like it to tell me why an interrupt of PC2 is not carried out.
A site of this source code is this place.
https://sourceforge.jp/projects/cc1101atxmega/scm/svn/tree/247/trunk/test_interrupt_02/
kenji maehara
OK I admit I don't know Xmega but it seems very unlikely to me that activity on PORTC would be triggering a PORTA_INT1 interrupt in the first place?
Surely if you want to do something similar to PORTA using PORTC you then use something like:
ISR(PORTC_INT1_vect)
	test_cnt++;
Oh and maybe it happens somewhere else but your slave_main() shows no sign of "sei()" so how do interrupts ever occur anyway?
Hi clawson,
Thank you for your advice.
I got a wrong port simply. I made modifications and was settled.
	test_cnt++;
	//	beep_on_off(1);
Thank you for your help.
kenji maehara
