AVR Xmega 64 bits floatting point support
8 posts / 0 new
I am currently using the ATmel Studio 6.2 IDE on a project. I am running into some issue where the 32 bits floatting point does not give me enough accuracy. Anybody has recommendation into either a 64 bits floatting point that is available for the Xmega256D3 or
some other IDE available that support it?
Charles
Maybe something from this link can be usefull:
https://www.avrfreaks.net/forum/d...
IAR EWAVR has 64bit floating point;
Alternatively, AVR GCC has 64bit fixed point.
ftp://ftp.iar.se/WWWfiles/AVR/webic/doc/EWAVR_CompilerReference.pdf (5.3MB, "Basic data types—floating-point types", page 271)
http://gcc.gnu.org/wiki/avr-gcc#Fixed-Point_Support
64 bit floating point on an 8 bit AVR - not going to be very fast!
the usual solution for more accuracy is not brute force 64 bit doubles, but rather, re-think the algorithm.
Imagecraft C also has support for 64bit doubles (in the "pro" version.)
I'm guessing that you are either:
(a) writing a scientific calculator
(b) doing GPS calculations accurate enough to target a housefly buzzing on the surface of the moon
Another solution might be IBM's decimal library. This has since passed into the public domain and is, I believe a component of GCC on some architectures. Not sure if it's available for avr-gcc or what the plans are to add it there though.
Having said that I seem to remember that when asked SprinterSB said that avr-gcc could be configured and built to have 64bit FP simply as a parameter to the configuration. But as this is not turned on by default there must presumably be some reason why (performance perhaps?).
As with others here I think there probably has to be a "better way" to achieve what it is you are attempting like fixed point or scaled integers or whatever.
Remember that any form of 64bit variable on an AVR is going to end up occupying 8 registers for each component of the calculation. While the 32 register AVR probably has enough it's likely to involve a loft of "shuffling about" by the compiler to get the values into the right place at the right time. This is likely as true for uint64_t as it is for 64 bit double.
Thank you all the inputs. It is appreciated
Charles
How hooked to C or ASM are you?
Bascom has a 64 bit data type.
