Code not executing properly with xmega256D3
12 posts / 0 new
I am using an Xmega256D3 using Atmel studio 6.2, AVR/GNU C compiler version 4.8.1 and FreeRTOS. I am running into some weird issue. I have the following code:
    if (gas_select <= MAX_GAS_INDEX)
        dns = 0;
        for (b = 0; b <= 12; b++)
            val1 = powf(temp_K, (float)b);       //Calculate 12 order polynomial
            dns += (prm[b] * val1);
When first entering the loop, temp_K is 273.16 . The result on the first pass should assign val1 to 1 (273.15^0 = 1.0) but I get zero.
When I setup a break point, I get a value of 0 for val1. If I take the statement with val1 and move it into a other task, it works properly. Also the for loop does not show b be incremented
on every loop when using the AVROne debugger.
The code size now is 110986 bytes. I checked all the tasks stack allocations and the total heap size and could not find anything wrong.
Is there anybody that ran into similar problem and figure out how to fix this issue?
Thank You,
Charles
We'll need to know the types for dns, b, val1 and prm.
2 82,589,933 -1 The largest known Mersenne Prime (Dec 7, 2018)
dns,val1 and prm are float. (prm[] array of 13 float)
b is a char
Charles
The guys will tell you: I'm not actually a C mage.
According to math.h, powf is #defined as pow.
pow takes 2 doubles and returns a double.
double pow	(	double 	__x,
                double 	__y
well, that wasn't exactly legible.
I thought that powf handles float as parameters and pow handles double. I did not think that AVR8 compiler can handle double, just float as 32 bits. Anyway, I think the code is executing properly but the debugger is having some issue stepping through the code. I tried to set the function with no optimization and still got the same result.
void __attribute__ ((optimize("O0"))) function(prm1, prm2)
Thank You for the response!
Charles
It wouldn't surprise me if the debugger wasn't able to show you the floats while executing. The compiler seems to be smarter than the debugger, not to mention smarter than me.
I am thinking of getting some better tools for compiler and debugger. Any recommendation? I am thinking of IAR tools set
Charles
I don't know what polynomial coefficients you have so I tried with all of them set to 1.
    // Setup USART and printf
    int b;
    float dns = 0, temp_K = 273.15, val1;
        val1 = powf(temp_K, (float) b);
        dns += val1;
        printf("b = %d, val1 = %g, dns = %g\n", b, val1, dns);
    putchar('\n');
and got the following output from a ATXmega128a1
b = 0, val1 = 1, dns = 1
b = 1, val1 = 273.15, dns = 274.15
b = 2, val1 = 74610.8, dns = 74885
b = 3, val1 = 2.038e+07, dns = 2.04548e+07
b = 4, val1 = 5.56678e+09, dns = 5.58723e+09
b = 5, val1 = 1.52057e+12, dns = 1.52615e+12
b = 6, val1 = 4.15342e+14, dns = 4.16869e+14
b = 7, val1 = 1.13451e+17, dns = 1.13868e+17
b = 8, val1 = 3.0989e+19, dns = 3.11029e+19
b = 9, val1 = 8.46466e+21, dns = 8.49576e+21
b = 10, val1 = 2.31212e+24, dns = 2.32062e+24
b = 11, val1 = 6.31554e+26, dns = 6.33875e+26
b = 12, val1 = 1.72509e+29, dns = 1.73143e+29
The first val1 looks OK to me. Note that this is not a good way to evaluate polynomials, see for example Horner's method.
guggech wrote:
Any recommendation?
Before you give up on AVR GCC consider inquiring Embecosm.
Embecosm is doing some effort for Atmel.
Embecosm Logo
http://www.embecosm.com/services/support/
I don't know C, but often when someone mentions something along those lines its because a variable isn't declared volatile.
That may have nothing to do with your issue, but it is perhaps worth a quick check.
What DocJC wrote might be correct, but we really don't know since you posted almost no code...
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
Hi Snigelen,
It turnout that the problem is with the debugger that is showing the wrong value when stepping throuh the code. On the top of that there was some incorrect value in the prm table. The calcualtion computed by an Excel shhet does agree with the value calculated by the code.
Thank you for yourv response.
Charles
