ATSAMR21G18A In PCB
4 posts / 0 new
Hello, in order to print a PCB and weld a atsamr21g18a I need to buy an external antenna and a 16 MHz crystal. Any crystal with 16 MHz is ok? Or do I need a specific one?
In the page 1098 of the datasheet, it says that I should use a coil (L) - i thinks that's the name in english. What should be the value of this coil?
https://www.avrfreaks.net/comment...
Also, look at the parts list of the Xplained-Pro board...
Try to read this
        Atmel-42068-Crystal-Characterization-for-AVR-RF_Application-Note_AVR2067
Available from the atmel website.
Wish you luck...
Warm regards,
Charles
That's exactly what I was looking for. Thank you very much
