Power circuit design logic -- suggestion
5 posts / 0 new
I am designing a board where my AVR Microcontroller is powered by LM7805 regulator & my load requires 3.8 voltage, is powered by following voltage regulator NCP57302.
http://www.onsemi.com/PowerSolutions/product.do?id=NCP57302
As per the specs of NCP57302 to produce 3.8V i have selected :--
R1 = 30.96K
R2 = 15K
Is it the right set of resistors values to be used for producing 3.8V ?
Also I need some external circuit to be put on enable PIN of NCP57302. So that microntroller & control the turning ON/OFF the power supply of load.
Can some suggest this external circuit for controlling the enable pin of NCP57302 regulator by my microcontroller ?
I need my load to be switched off when board is powered on & microcontroller turn it ON after some time, for that i need some external circuit to fix enable pin at ground level on startup.
Please suggest.
//Katoch
Schematic
Katoch,
1. Your calculation is correct.
2. Tie the enable pin to ground via a 10K resistor. That will disable the device until you set your microcontroller to provide a "high" to the enable pin.
3. Why do you talk of 3.8volts, but label your circuit with 1.8volts?
4. I have deleted your second thread on the same topic.
Cheers,
Ross
Moderator
Thanks for replying.
   I have one question here.
   Now if i connect enable pin to ground by 10K resistance & apply high  on my microcontroller o/p pin. Then what level will be input to the EN pin of the regulator.
   Will it be high on Enable pin of regulator ? Or high signal send by the microcontroller will be get the ground through 10K (R33) resistor & enable pin will be on ground again ?
   It should be the potential drop across 10K resistor right ?
   Please suggest.
      Corrected & reposted the schematic.
By mistake i posted twice
2. When the microcontroller outputs a high (~5volts), the enable pin will see that voltage and a small current will flow through the 10K resistor to ground. When the microcontroller either outputs a low or is in its tri-state mode during bootup, the enable pin will be grounded.
Thanks for helping me in this.
katoch
