RTS/CTS flow control for comms with GSM modem
4 posts / 0 new
Hello there,
I want to connect an ATmega162 with a sony-ericsson GM29 GSM modem(AVR as DTE). The problem is that the modem has hardware flow control on its RS232 port enabled by default, and I have trouble implementing hardware flow control an the AVR side. What I have tried so far is pulling the RTS line low, and wait CTS line (connected to INT0) to trigger an interrupt. Then allow the program to send a byte and pull RTS line high again. Is this right? Any help would be greatly appreciated.
The Nut/OS AVR uart-driver is a good source of information how to implement RTS/CTS flow-control with an AVR.
I have a more precise question. It makes any difference if the RTS signal is held low just until I get the CTS responce or until the whole frame is being transmitted? Any help would be greatly appreciated. I can't find a timing diagramm anywhere.
Problem solved. I may post this in the academy section when I will find time.
