Hardware way to sync 328 timer0 and timer1?
3 posts / 0 new
I want to play with 3 channel pwm out, so I thinks: set xtal fuse for full swing osc, jumper xtal1 to pd4 and pd5 (t0 and t1 ext clk inputs), and now I have 4 8 bit pwms all running in sync. Clever? Stupid? Some unseen problem?
They share the same prescaler and that has a reset that should allow you to synchronize. No need for external connections to T0, T1.
Steve A.
T0 and T1 must be driven slower than CLK/2, so this wouldn't work.  As Koshchi says, you can use the TSM bit in GTCCR:
GTCCR = (1<<TSM);
TCCR0A = your_mode_bits;
TCCR0B = your_mode_bits | your_prescaler_bits;
TCCNT0 = 0;
TCCR1A = your_mode_bits;
TCCR1B = your_mode_bits | your_prescaler_bits;
TCCNT1 = 0;
GTCCR = 0;
