Effect of GCC "-pipe" option
5 posts / 0 new
I'm actually using the GCC ARM version for SAM D20/D21/R21 - but I guess it's generic GCC?
Wanting to see the preprocessor output, I added '-save-temps' to the Miscellaneous project options.
It works, but I get this warning:
Warning    1    -pipe ignored because -save-temps specified    arm-none-eabi-gcc.exe    0    0    SAMR21_XPRO
 So the question is: does the '-pipe' option actually have any significant effect?
This discussion - http://stackoverflow.com/questio... - would seem to suggest that it's generally not significant; what do others here find with Atmel Studio?
Not near a PC to try it now but I'm sure I have just used -save-temps for ARM code in Studio in the past and I don't ever remember seeing such a warning.
(also used it with the arm-gcc in Code Red for NXP and as I remember it there was no problem there either).
gcc can be configured for various mix of default options. Try to run your variety of gcc on any input .c file with -Q -v  to see them.
JW
The question is not about the warning - the warning is benign.
The question is:  does the '-pipe' option actually have any significant effect in the experience of other Atmel Studio users?
And the answer was not to your question ;-) rather, to Cliff's comment that he's never seen this warning.
But, if you want an completely unqualified and unusable answer, IMO, any other users' experience is void, as performance of pipes versus files would depend on a gazillion factors of the particular user's hardware and OS setup and state...
Jan
PS. Real embedded programmers wouldn't touch M$VisualAnything with a stick... ;-)
