AVR/GNU C++ Compiler - duplicate 'inline' error
10 posts / 0 new
Disclaimer: I already know about the warning that ASF may not work well with C++ projects, everything I am using works with the exception of this.  I have -std=c++11 defined in other flags in the C++ miscellaneous tab.
Calling all compiler gurus. ;)
In ASF/common/services/ioport/mega/ioport.h there are functions that are declared and defined like this:
__always_inline static inline function(...) {...}
This is not a problem for the AVR/GNU C compiler but it is for the AVR/GNU C++ compiler as it sees the "__always_inline" and the "inline" as duplicate and flags them as errors.
I have worked around this by removing the "inline" from the definitions.  Is doing so a problem?  Is there a compiler flag to ignore the duplicate error?  Can you explain why the C++ compiler has a problem with this?
EDIT: I guess what I am questioning is whether the "inline" following the "__always_inline" is superfluous or not.
I answered my own questions.  (Amazing what a little sleep can do.)
The macro definition of "__always_inline" in ASF\mega\utils\compiler.h explained the problem:
#define __always_inline inline __attribute__((__always_inline__))  <- Added for completeness of example
__always_inline static inline function(...) {...}  which becomes
inline __attribute__((__always_inline__)) static inline function(...) {...} <- duplicate 'inline'
Now I will let Atmel know that they have a problem in their header files. frown  I will mark this thread as solved once I get an answer from Atmel.
Does the attribute __always_inline__ make inline redundant?
That is the real answer that I am looking for and so far haven't found.  If it is, then the remaining "inline" in the function definitions would indeed be superfluous, that is if I got the correct meaning of your question.
inline __attribute__((__always_inline__)) static inline function(...) {...} <- Is the inline here superfluous since we already have the attribute "always_inline__"?
No, there is a least one difference (that I rely on (or abuse) in my code). Without "inline" the compiler (at least all the versions that I used so far) complain about "defined but not used" function.
Thanks, that seems to concur with the results of the testing that I have just done.  I would like to hear more on the details regarding "rely on (or abuse)".  What do you use it for?
I usually want the compiler to complain about (pretty much) all unused functions, even those defined as "static inline". For that, I define them as "static __attribute__((always_inline))" rather than "static inline". (Occasionally I do have functions that I don't want the compiler to complain about. Then I define them as "static inline __attribute__((always_inline))". Or just "static inline", if I don't care about the inline-ness guarantee.)
Hi Larry,
could you please send me an example of C++ + ASF project which compiles and links fine? I am using Atmel Studio 7 a and SAM4E Xplained Pro kit, but cannot get even a plain sample C++ project with ASF board support package. I am getting this  error :
Severity Code Description Project File Line
Error 'CKGR_MOR_KEY_PASSWD' undeclared (first use in this function) GccApplication2 C:\Projects\Atmel\GccApplication2\GccApplication2\src\ASF\sam\utils\cmsis\sam4e\source\templates\system_sam4e.c 66
thanks
@fkaudch: Stop hijacking threads on subjects unrelated to the problem you have. Please.
...and Larry hasn't been around for a long time, hope he is OK, maybe driving around Europe in some Lamborghini or other bucket of rust.....
