I'm happy that you've gained something from it. Using the bit_mask table is a bit of a throwback to when i first wrote the code on a 8051 processor. With the AVR you could flip a coin vs using shift operators. With an ARM processor, using a shift operator would be more efficient.
I've used the framework on a number of commercial projects spanning nearly 20 years. There's many little boxes ticking away happily around the world.
What makes the threads context switch is inserting a call to "yield", somewhere in the code of the spawned methods, or why not from an interrupt handler (ISR) written in tinythreads.
If you want to know the implementation of the yield method - which triggers the context switching - then you'll have to do some coding yourself (HINT: It's four lines of code, including turning on and off interrupts).
Yield shall enqueue the current thread and dispatch the one in the waiting queue. (PM me if you're not up for my bullshit, I'll show you)
If you yield within an isr, is that not preemption?
Oh, yeah sure. Right now I've hooked my Arduino up to an LED (I'm strapped for parts, can't make anything more advanced at the moment), that one blinks on/off every 300ms, and the on-board LED blinks on/off every 200ms, both using very simple endless loops with _delay(). The interrupt comes from the WDT set to timeout every 32ms, works flawlessly to the naked eye.
As a side note (nothing to do with multitasking, but interrupt handlers), depending on your system and what the requirements are, you can get away with just runnig your code in the interrupt handlers (: That way you can sleep in the main-loop, saving energy!
This tutorial was not meant to be the last word in multitasking - as i said up front, it is an example of a simple, cooperative tasker. There are a number of ways to achieve the same or similar results.
Why don't you write up your approach as a tutorial?
"How have you proved that your chip is running at xxMHz?" - Me
"If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand." - Heater's ex-boss
It's not an impossibility, but I'm not the original author of this program. Not that it's copyrighted or anything but since I didn't write it myself (and I'm really no C programmer) I might not be able to answer those really tricky questions. We'll see, until then all information is in those slides and in the submitted code, only thing missing is the implementation of yield which I can help you with. The mutexes I haven't looked into since the threads I've run haven't shared common resources, but I have the code for those aswell.
I'd suggest that if you find yourself needing to do it then you have partitioned your tasks wrongly.
My thoughts to. In multi-tasking it is often the case that you have one task that "does a job for" another task but rather than CALL it you might typically have the "worker" task block on a mutex or semaphore then, when the parent task wants the job done it release the shared object that triggers the other into life. Anotther way is for the parent to post a request into a message queue of the child task and when it receives and "OK, go for it" message it springs into life. This is quite different to synchronously calling functions in one task from another. You have to start thinking about the problem in a "different way" when you try to share work across threads and tasks in a multi-tasking system.
At the end of the day think about it just like you get to write three or five (or however many) different main()s in a single program. Each "does it's own thing". But a bit like when in Windows your word processor sends a document to the print queue along with another document already waiting to be printed from a spredasheet, sometimes the main()'s "talk" to each other. That's at the highest level of course but really the issue is pretty similar.
So in what context do you see the need for one task to "call" another?
Of course there are things that both tasks might call - I bet they might both be tempted to call printf() but that does not "belong" to either task really - it's a shared resource hey can both use. Of course that raises another issue. If one does printf("hello") and one does printf("goodbye") at the same time how do you prevent the user seeing "hegloodlyeo" ? (or maybe that's what you want?). This is really where a mutex (or semaphore if more than 2 tasks) might come into use. A mutex (mutual exclusion) ensures that only one task can "own" a resource at a time. So both programs call get_mutex(printf); printf("hello"/"goodbye"); release_mutex(printf). The one that "gets there first" gets control and can complete his printf() then he release the lock. Meanwhile the other task is "stuck" inside get_mutex() waiting for it to become available. When the first task calls release_mutex() that allows the get_mutex() to then complete and he can then do his printing. So the user sees "hellogoodbye" or "goodbyehello" depending on which got there first.
thanks brian and clawson.....I am not willing to do semaphore or something like that because it will get more complicated. I will re-code the tasks so that there is no need to call one from another.
And thank you clawson for such a wonderful explanation.
I re-coded it so that there is no need to call one task from other. But I am getting a strange problem after running it a while. It is getting stuck somewhere and not coming out. How to figure it out where it is getting stuck?
It kind of depends what "stuck" really means - you meant the task switching preemption actually stops or simply that one of the tasks goes into an infinite loop?
Anyway an OCD debugger (JTAG/debugWire/PDI/whatever) is usually the best for this kind of thing or failing that (if not too much external stimulation is involved) the simulator in Studio. Run the code until it is "stuck" then simply break execution and find out where it is. Maybe follow it into the task preemption (assuming that's till going) and watch it as it returns into each task. Is one (or all even?) "stuck" in a loop waiting for something to happen that never will?
It seems one of the task is going into an infinte loop. This problem is happening randomly like sometimes after 10min, sometimes after 15 min and like that. What do you mean by "Maybe follow it into the task preemption (assuming that's till going) and watch it as it returns into each task." How to do that?
As I say just run the code in a debugger or simulator to the point where it "locks" then break execution to find out where it is stuck (which should then tell you why). If some tasks are still going OK then just keep stepping execution until it gets into the task that is not running.
(BTW this is one of the downsides of multi-tasking - it can often be trickier to find out what's wrong when some part of the code stops working).
How many tasks do you have? Could you get each task to flash an LED? If each task sets an I/O bit on entry and clears it on exit you could probe with a scope to see what's toggling and what isn't.
Or, get each task to write its task number to multiple LEDs. When it freezes the display will indicate the last task to run.
Cliff, there is no preemption happening in the bit of code i wrote. Everything runs to completion.
Sktnandy - see above. Your task can't sit in a loop - when it is called it must do what is necessary and exit within its time slot. If it has to wait for something, you use a state machine, set the state and come back later.
Further to what Brian has suggested, output the task number via the uart. For many years i didn't use (or have) in circuit debug so techniques like flashing leds and uart output are powerful means of identifying what is happening. Even recently i output recovered clock and data signals on i/o bits then used a salae logic analyser to see what was happening.
how much time should I set for TWINT? Have not checked the TWEN flag. what will be the value of TWEN in this case? controller is in master transmitter mode
It could be a number of problems. Do you have the correct pullup resistors? What have you done to investigate the problem? What circumstances lead up to the problem? Use the sound card as an oscilloscope and capture the i2c bus. You'll be able to see where it hangs and hopefully solve the problem yourself.
thnks for the reply. I searched net but it could not find anything to resolve the problem. Pull up resistors are 2k2. As per the code, i2c routine get called after every 250ms. And after a while it gets stop at that line, though the code is going to interrupt after every 10ms. I checked this with a led.
Posted by DAFlippers: Thu. Jan 22, 2015 - 10:29 AM
1
2
3
4
5
You have no default case in the below so if i2c_transmit(type) is called with type != I2C_START | I2C_DATA | I2C_STOP you won't make any change to TWCR but you will enter the while loop. Is that what you intended?
If not then set a flag (LoopFlag) in cases below, clear LoopFlag in a new default case and add LoopFlag test as condition for While.
David
unsigned char i2c_transmit(unsigned char type)
switch(type)
case I2C_START: // Send Start Condition
TWCR = (1 << TWINT) | (1 << TWSTA) | (1 << TWEN);
break;
case I2C_DATA: // Send Data
TWCR = (1 << TWINT) | (1 << TWEN);
break;
case I2C_STOP: // Send Stop Condition
TWCR = (1 << TWINT) | (1 << TWEN) | (1 << TWSTO);
return 0;
// Wait for TWINT flag set in TWCR Register
while (!(TWCR & (1 << TWINT)));
// Return TWI Status Register, mask the prescaler bits (TWPS1,TWPS0)
return (TWSR & 0xF8);
Posted by joneewheelock: Thu. Oct 29, 2015 - 04:22 AM
1
2
3
4
5
If I understand correctly, there is a heavy dependency on task_timers. In case few task_timers are of 10 msec and their priority is also high, other tasks may not get chance to run. So we have to be careful in selecting task_timers right?
There's a fixed priority with the tasks. Thus a task can 'steal' all the cycles. The general idea is that you don't allow that to happen. Each task does what it needs to do in its 10ms slot and must yield. You can normally do quite a bit of work in that time. Thus the term 'co -operative'.
The AVR can only do one shift per cycle (compare this with an ARM that can do n bits in one cycle). My example takes a constant amount of time vs the bit shift taking a variable amount.
Ah k I see. I was also wondering if using a Timer/counter could be an option to measure the cycles a function takes. This is more of an exercise for me to understand parts of my code better.
I was also curious how small the time slices could get. When transmitting/receiving data via UART, I was wondering if your system could handle a lot higher baud rates.
I tried to do some calculations and am wondering on peoples thoughts. These calculations were done with 11bits in mind (1 start, 8 data, 1 parity, 1 stop)
Time between transmissions/receptions in ms = 1/((baud/11)/1000)
At 9600 baud it would take 1.146 ms between tx/rx
At 250000 baud it would take 0.0440 ms between tx/rx
So the time slices at 9600 baud would be 100us and for the higher baud rate would be 1us.
The UART RX has a two-word buffer, plus the incomming shift register, so it can buffer up to three characters. At 250kbps 8N2, that's 132 us. At 16 MHz, that's 2112 cycles.
Let me guess... DMX/RDM? I'd suggest you handle that in an ISR, and buffer an entire DMX frame (or whichever addresses in which you're interested) in SRAM. Your tasks would then access that buffer.
Although you said 8P1, so maybe not DMX...?
"Good judgement comes from experience. Experience comes from bad judgement."
"Fast. Cheap. Good. Pick two."
"Read a lot. Write a lot."
Ah forgot about the buffer. Would it be sketchy to wait and unload the received words once the buffer and shift register are full? On an interrupt i guess it would not be.
Cheers for making me aware of that. Just went through the datasheet and found what you mentioned, YAY learning!
So that is 2112 cycles between each unloading of the 3 bytes? I was trying to work this out to see when having such a high baud was problematic, however every design is situation dependent. And was asking to see if my math was right, which it seems to be.
I'm not doing anything fancy yet, as I did had to google DMX/RDM. It was more to learn about this multitasking idea and find the limitations that I need to be aware of.
And now I just read the flowchart pic at footer of your post. I feel it is fairly apt considering Im fairly new to MCU's and often dig myself a hole by trying to optimize and write the initial code at the same time.
3 bytes is the outside limit. The moment the next start bit arrives, a data overrun condition is flagged with the DORn bit, and the latest incoming word is dropped.
There is no way to determine programmatically how many words are waiting in the RX buffer, or how many bits are in the shift register. The only determination you can make is that the receive buffer contains either:
0 words (UDRE = 1)
1 or more words (UDRE = 0)
Some models of AVR have a start frame detection bit, so you could get a warning that there is an incoming word in progress, but that is typically used to wake the device from sleep mode.
In practice it is sufficient to service the receive interrupt with every word, so usually the two-deep-buffer-plus-shift-register only ever gets partly full. The extra depth is useful when your app gets excessively busy on occasion, allowing it to catch up without losing any incoming data, but this behaviour should be profiled to ensure overrun isn't possible, or that it is properly handled if it does.
While you can design your app 'to the edge', this must be done with care.
Re: flow-chart... Randall Monroe is one of my favourite humans whom I've never met.
It's good to get feedback from readers, thanks.
TopTime to update to __flash and drop the pgm_read*() stuff perhaps? ;-)
TopAgreed.
TopI have some useful information on realtime systems from my university;
Some appropriate lecture slides (this presents one way of "simultaneous" execution on a single core processor, we used AVRs in the labs).
http://www.sm.luth.se/csee/courses/d0003e/lectures/lecture4.pdf
And a light weight multi-threading kernel, tinythreads. However, some of the methods are unimplemented - that's for the students to do.
http://www.sm.luth.se/csee/courses/d0003e/labs/tinythreads.h
http://www.sm.luth.se/csee/courses/d0003e/labs/tinythreads.c
And to actually use the kernel, use "spawn" from main on methods that do not terminate. As shown here, example:
http://www.sm.luth.se/csee/courses/d0003e/labs/mytest.c
sol i sinne - brun inne
TopIf you yield within an isr, is that not preemption?
TopOh, yeah sure. Right now I've hooked my Arduino up to an LED (I'm strapped for parts, can't make anything more advanced at the moment), that one blinks on/off every 300ms, and the on-board LED blinks on/off every 200ms, both using very simple endless loops with _delay(). The interrupt comes from the WDT set to timeout every 32ms, works flawlessly to the naked eye.
TopAs a side note (nothing to do with multitasking, but interrupt handlers), depending on your system and what the requirements are, you can get away with just runnig your code in the interrupt handlers (: That way you can sleep in the main-loop, saving energy!
TopThis tutorial was not meant to be the last word in multitasking - as i said up front, it is an example of a simple, cooperative tasker. There are a number of ways to achieve the same or similar results.
TopOf course! (:
Top@Tickstart
TopIt's not an impossibility, but I'm not the original author of this program. Not that it's copyrighted or anything but since I didn't write it myself (and I'm really no C programmer) I might not be able to answer those really tricky questions. We'll see, until then all information is in those slides and in the submitted code, only thing missing is the implementation of yield which I can help you with. The mutexes I haven't looked into since the threads I've run haven't shared common resources, but I have the code for those aswell.
TopThanks for such a wonderful tutorial....waiting eagerly for the 2nd part...
Saikat
TopCan I call another task from one task? Will it make create any problem?
TopWhy would you want to do that?
TopMy thoughts to. In multi-tasking it is often the case that you have one task that "does a job for" another task but rather than CALL it you might typically have the "worker" task block on a mutex or semaphore then, when the parent task wants the job done it release the shared object that triggers the other into life. Anotther way is for the parent to post a request into a message queue of the child task and when it receives and "OK, go for it" message it springs into life. This is quite different to synchronously calling functions in one task from another. You have to start thinking about the problem in a "different way" when you try to share work across threads and tasks in a multi-tasking system.
Topthanks brian and clawson.....I am not willing to do semaphore or something like that because it will get more complicated. I will re-code the tasks so that there is no need to call one from another.
TopI re-coded it so that there is no need to call one task from other. But I am getting a strange problem after running it a while. It is getting stuck somewhere and not coming out. How to figure it out where it is getting stuck?
TopIt kind of depends what "stuck" really means - you meant the task switching preemption actually stops or simply that one of the tasks goes into an infinite loop?
TopIt seems one of the task is going into an infinte loop. This problem is happening randomly like sometimes after 10min, sometimes after 15 min and like that. What do you mean by "Maybe follow it into the task preemption (assuming that's till going) and watch it as it returns into each task." How to do that?
TopAs I say just run the code in a debugger or simulator to the point where it "locks" then break execution to find out where it is stuck (which should then tell you why). If some tasks are still going OK then just keep stepping execution until it gets into the task that is not running.
TopHow many tasks do you have? Could you get each task to flash an LED? If each task sets an I/O bit on entry and clears it on exit you could probe with a scope to see what's toggling and what isn't.
TopCliff, there is no preemption happening in the bit of code i wrote. Everything runs to completion.
TopI found the problem using LED while running it in the simulator. I saw the code is stuck at this I2C routine
while (!(TWCR & (1 << TWINT))); // Wait for TWINT flag set in TWCR Register
Below is the complete code where it is getting stuck.
switch(type)
break;
break;
return 0;
The task which is doing this I2C communication is taking toatl 1ms when it is running fine.I checked it by toggling a bit.
I dont know why it is stuck at that while() function. Also I am calling the task after every 250ms
TopYou should implement a timeout while waiting for TWINT.
Also, examine TWEN when your task hangs. Is it set?
Tophow much time should I set for TWINT? Have not checked the TWEN flag. what will be the value of TWEN in this case? controller is in master transmitter mode
Topchecked the TWEN bit. It is set. What could be the reason TWINT bit is not getting set?
Topplz help me
TopIt could be a number of problems. Do you have the correct pullup resistors? What have you done to investigate the problem? What circumstances lead up to the problem? Use the sound card as an oscilloscope and capture the i2c bus. You'll be able to see where it hangs and hopefully solve the problem yourself.
Topthnks for the reply. I searched net but it could not find anything to resolve the problem. Pull up resistors are 2k2. As per the code, i2c routine get called after every 250ms. And after a while it gets stop at that line, though the code is going to interrupt after every 10ms. I checked this with a led.
TopAs i said, it could be a number of things causing the problem. You need to dig for more evidence.
TopYou have no default case in the below so if i2c_transmit(type) is called with type != I2C_START | I2C_DATA | I2C_STOP you won't make any change to TWCR but you will enter the while loop. Is that what you intended?
David
Top*Tickstart's derailment of this thread has been moved to the off-topic forum. Moderator*
TopIf I understand correctly, there is a heavy dependency on task_timers. In case few task_timers are of 10 msec and their priority is also high, other tasks may not get chance to run. So we have to be careful in selecting task_timers right?
TopThere's a fixed priority with the tasks. Thus a task can 'steal' all the cycles. The general idea is that you don't allow that to happen. Each task does what it needs to do in its 10ms slot and must yield. You can normally do quite a bit of work in that time. Thus the term 'co -operative'.
TopI'm a bit late to the party but this page is still very interesting. I was curious if there were problems with changing the section:
to:
Or am I missing some information regarding the use of pgm_read_byte(), or that bit shifting is not the best solution in this scenario.
TopThe AVR can only do one shift per cycle (compare this with an ARM that can do n bits in one cycle). My example takes a constant amount of time vs the bit shift taking a variable amount.
TopAh k I see. I was also wondering if using a Timer/counter could be an option to measure the cycles a function takes. This is more of an exercise for me to understand parts of my code better.
Does this sound correct?
Cheers.
TopThe UART RX has a two-word buffer, plus the incomming shift register, so it can buffer up to three characters. At 250kbps 8N2, that's 132 us. At 16 MHz, that's 2112 cycles.
TopAh forgot about the buffer. Would it be sketchy to wait and unload the received words once the buffer and shift register are full? On an interrupt i guess it would not be.
Top3 bytes is the outside limit. The moment the next start bit arrives, a data overrun condition is flagged with the DORn bit, and the latest incoming word is dropped.
TopPages
