Atmel Studio 6.2 and 6.2 SP1: Watch Window Hexadecimal Display does not work
5 posts / 0 new
As you can see, I have 'Hexadecimal Display' checked, but the one format that is not used at all is hexadecimal!!
Atmel Studio 6.2 SP1 Watch window  ignores the 'Hex Display' setting
Seriously - who on earth uses Octal these days?!
I have also posted this on The Other Forum, but it won't let me attach the screenshot, and there seems no way to contact the Administrators there!
http://www.at91.com/discussions/viewtopic.php/t,23151.html
Was this with GDB enabled or disabled? (if you don't know, then enabled for ARM and disabled otherwise...)
:: Morten
Sorry for the delay; I haven't had cause to use the debugger for a wile.
I checked and, yes, that was with GDB enabled.
Changing to GDB not enabled fixes it.
So the "bug" is in or due to GDB.
It seems that GDB likes to think that it knows best, and may choose to ignore your setting of 'Hexadecimal Display'
Well, it's still pretty lame - just a blanket, global 'everything in hex" or not.
angry
Apparently, it is (or should be) possible to specify formats individually to each Watch item:
http://www.at91.com/discussions/...
Hardly what you'd call a Graphical UI - but better than nothing, I suppose!
