Atmel Studio (Visual Studio) 'Untabify' does not work (sic)
3 posts / 0 new
See: https://connect.microsoft.com/Vi...
So Microsoft say it "works" (sic) as they intended - but that may well not be the way you'd like it to work...
It certainly isn't the way I would like it to work!
Cross-post: http://www.at91.com/discussions/...
Tabify does not work either.  Are you just bitching?smiley
This works.  Tools>Customize, select Commands, Toolbar, Standard toolbar, Add Command..., select Edit in Categories, then scroll down to "Convert Tabs to Spaces", move it down to the bottom.  Do the same for "Convert Spaces to Tabs".
