problem with position of my codes
15 posts / 0 new
Hi.
I do not know where is the best location in this forums to post my problem so I posted here :D
I write a function but it does not work fine, after couple of hours! I change to position of my function from line 500 to line 1000! and now every thing is fine!
could you please tell me why?!
If your function failed after 2 hours,   you have probably got a memory corruption problem.
I would guess that moving your function in the C file will not solve the problem.    It might take 4 hours or 24 hours.    It will still fail.
Typical causes are allocating char buffer[6] and writing to buffer[6].    A 6-element array goes from 0..5.
Hi. thank you for your consideration.
but I had a writing bug :D in my previous post, I missed a comma in that sentence so you could not get my Purpose.
I mean after 2 hours that I think on that problem, I changed the position of my code.
in addition my function did not work when I changed position of function to previous line(500) again.!!
Seriously,   you have a memory corruption problem.
Look for arrays that are too small or local variables that are too big.
Look at the Memory report at the end of the Build.
what kind of problem happen, if I have a local variables that are too big?!
It sounds as if you have a fairly large file.   e.g. 1000 lines
So it is too big to copy-paste into a message.
But you can always attach the C file to a message or post a link to Github, Pastebin, ... or whichever website it is on.
If you have too many local variables,   the stack gets corrupted.   GCC does not tell you.
If you have too many global / static variables,   GCC tells you that you have used too much SRAM
Attach your code, do not post it, so that we don't have to guess why your code does not work.
EDIT: David beat me to the punch.
Do you think it's wise to be writing 1000+ line files in the first place. Aim for modularity and you should find that no source file need be more than a few hundred lines. Thinking in such a "modular" way will likely improve the design and stability of your code too. Aim to test the 5 or 10 functions in a few hundred line file in isolation. Problems like arrays out of bounds will hopefully show themselves at this stage (assuming you write good test harnesses) so the only other work is then to bolt together the highly tried and tested modules at the end of the integration phase.
I can't believe I'm about to say this but: C++ helps this process.
(if only Johan were around to hear that!).
I heard it.  devil
so do you think that this problem happen because I used many local variable in my function ?
How can we possibly know that?
You haven't attached your code for us to see, and even if you did I doubt anyone is going to look at a file with 1000 lines of code to see what the problem might be.
I think you need to re-structure your program as clawson suggested.  In the process of doing that you may find the problem yourself.
thank you for guiding me. so I will separate my functions into several files and test that again, then I will post the result here.
1000 lines is a lot but not terrible.
Make sure you find the problem before you break more things.
If your program does strange things you have a wild pointer or a buffer over run , pretty much guaranteed.
Keith Vasilakes
Firmware engineer
Minnesota
OP: do you use malloc() ? Or New ?
Or a stack overrun.
