AVR Studio v4.12.461 SP1 released (revision update)
86 posts / 0 new
AVR Studio 4.12, build 460 (46MB): http://www.atmel.no/beta_ware/as...
AVR Studio 4.12, Service Pack 1, build 461 (7.7MB): http://www.atmel.no/beta_ware/as...
AVR Studio 4.12 Service Pack 1 Release Notes: http://www.atmel.no/beta_ware/as...
AVR Studio 4.12.450 RC1 Change log:
New part support added:
 ATTiny26B (ICE50)
 ATtiny46 (ICE50)
 ATtiny86 (ICE50)
 ATmega640 (JTAGICE mkII, STK500, AVRISP)
 ATmega1280 (JTAGICE mkII, STK500, AVRISP)
 ATmega1281 (ICE50,JTAGICE mkII, STK500, AVRISP)
 AT90CAN32 (ICE50,JTAGICE mkII, STK500, AVRISP)
 AT90CAN64 (ICE50,JTAGICE mkII, STK500, AVRISP)
All the above parts are supported by simulator and AVRASM2.
Features:
Data breakpoints with hit count and program breakpoints with hit count are now supported on ICE50, JTAGICE mkII and simulator. The breakpoint system is now redesigned to be more robust and reliable. Also introducing a new fully customizable breakpoints and tracepoints window to offer a convenient overview and easy navigating between all breakpoints and tracepoints. Data breakpoints can easily be set by drag’n drop variables from the source editor and memory windows to the breakpoints and tracepoints window.
Program breakpoints can now be set with run-time hit counts. Data breakpoints can be set to break on read or/and write access to any memory location, including numerous conditions as larger than, less than, equal to and range. All the breakpoints can be used as watch-points, and are always properly saved and restored between project sessions even if source files are modified.
Please note that support level vary between the different debug platforms. See the actual user guides for more information about support details.
Integrated development with any AVR GCC compiler is now supported with AVR Studio. WinAVR or any other AVR GCC compiler must be downloaded and installed separately, but with IDE support in AVR Studio you can easily and fast get started with C code development and debugging. Please refer to the AVR GCC IDE user guide for more information.
The user interface has been improved with a new docking system called smart docking. Using a new docking mechanism, you will see exactly where the dragged window can be docked. Small markers will indicate sides where the bar can be docked. This is default on, but may be turned off to use the old docking method.  With detachable tab windows you can place and group your windows wherever you want. Also introducing workspace configuration that let you easily save and restore your desktop set-up.
AVR Studio now supports the new AVRISP mkII that offer USB, more robust and faster programming. See the user guide for more information.
AVR Studio now supports the MicroC/OS-II RTOS plug-in that is distributed in an own package.
A new version of the USB driver is included. Version 7.01.
Giorgos.
EDIT 1 (Oct 03): Program revision update, from 4.12.450 RC1 to 4.12.451 RC1
EDIT 2 (Oct 03): Program revision update, from 4.12.451 RC1 to 4.12.452 RC1
EDIT 3 (Oct 07): Program revision update, from 4.12.452 RC1 to 4.12.453 RC2
Fixes in build 453:
* Fixed errornous case-sensitiveness for symbol lookups that caused problems for assembly watch.
* Now saves separately the progmode that was last used by the JTAGICE mkII. Defaults to JTAG mode. Enhanced error messages.
* Fixed bug regarding I/O breakpoints. Now works.
* Fixed problem with space in project name.
* Fix in trace filter dialog
EDIT 4 (Oct 14): Program revision update, from 4.12.453 RC2 to 4.12.454 RC3
Fixes in build 454:
* Fixed performance and network problems. Projects with many files could experience major performance problems.
* ICE50 trace fix. Bug in mapping between trace data and source.
* COFF parser fix. Bug in source file mapping for functions returning pointers.
* Simulator fix. bug when using 2 AVR Studio simulator sessions at the same time.
* Fixed bug with auto open feature.
* Fixed problem that could cause network traffic on idle.
* Fixed bug in "old" plugin-in's. Bug could cause hang when using context menus.
* Various fixes in AVR-GCC project
- Bug fixed: Error messages referring to line:column not recognized.
- Enhancements: Added 'edit' button for editing options. resized optionslistbox to make room for longer options.
Double-click event on optionslistbox edits item.
- Bug fixed: renaming configuration could cause make problems.
- Bug fixed: problem with superfluous spaces.
- Order of include directories is now reflected in the build.
- Bug fixed: Add multiple libraries did not work.
- Bug fixed: Crash when changing stack settings.
- Bug fixed: removed -o option for build steps.
- Bug fixed: Better error handling for invalid configuration names.
EDIT 5 (Oct 30): Program revision update, from 4.12.454 RC3 to v4.12.456 RC4
fixes in build 454:
- Double-click event on optionslistbox edits item.
EDIT 6 (Nov 04): Program revision update, from v4.12.456 RC4 to v4.12.460
Huge change log of build 460:
* Part support
- ATTiny261 (ICE50)
- ATtiny461 (ICE50)
- ATtiny861 (ICE50, JTAGICE mkII, STK500, AVRISP)
- ATmega640 (JTAGICE mkII, STK500, AVRISP)
- ATmega1280 (JTAGICE mkII, STK500, AVRISP)
- ATmega1281 (ICE50,JTAGICE mkII, STK500, AVRISP)
- AT90CAN32 (ICE50,JTAGICE mkII, STK500, AVRISP)
- AT90CAN64 (ICE50,JTAGICE mkII, STK500, AVRISP)
All the above parts are supported by simulator and AVRASM2. See the simulator section for more details about support details.
* Features
- Breakpoints
Data breakpoints with hit count and program breakpoints with hit count are now supported on ICE50, JTAGICE mkII and simulator. The breakpoint system is now redesigned to be more robust and reliable. Alsointroducing a new, fully customizable breakpoints and tracepoints window to offer a convenient overview and easy navigating
Data breakpoints can easily be set by drag’n drop variables from the sourceeditor and memory windows to the breakpoints and tracepoints window. Program breakpoints can now be set with run-time hitcounts. Data breakpoints can be set to break on read or/and write access to any memory location, including numerous conditions as larger than, less than, equal to and range. All the breakpoints can be used as watch-points, and are always properly saved and restored between project sessions even if source files are modified.
- Integrated AVR GCC compiler
- Docking System
- AVRISP mkII
AVR Studio now supports the new AVRISP mkII that offer USB, more robust and faster programming. See the User Guide for more information. Available from Atmel, Q4, 2005.
- RTOS
AVR Studio now supports the MicroC/OS-II RTOS plug-in that is distributed in an own package. Available from Atmel, Q4, 2005.
- USB driver
EDIT 7 (Dec 08): AVR Studio v4.12.461 Service Pack 1 released:
Change log of Service Pack 1 build 461: http://www.atmel.no/beta_ware/as...
I hope for nothing; I fear nothing; I am free. (Nikos Kazantzakis)
Sounded nearly too good to be true. I downloaded right away, installed and made the ubiquotous Windows restart. And...
it just worked!
No hassles. No hours of flabbergasting obscurities. And, this was a 1 minute test only. Lots of stuff to try out. But it seems to work!
And the new docking system is nice.
Sorry, but I have to shout: Thank You, Atmel!
Edit: The release notes say
but this document/section is missing (as is the "simulator Users Guide"). Not a catastrophe as everything seems pretty clear/intuitive if You are used to working with WinAVR utilities like Mfile.
Edit 2: Well, the section is in the installed tree, but the link to it in the end of the release notes is broken (and I cant find it in the help tree). Go hunt for the file avr-gcc_pluginhelp.chm in the directory C:\Program Files\Atmel\AVR Tools\Help (or something similar depending on how/where You installed AVR Studio.
I'm very happy with 4.11....so I'll wait untill everyone else gets the bugs out of 4.12 before I use it :-) and also wonder if assembler V2 has been fixed so that my code works on it like on V1.7x...still using the old assemler which works for me.
Hi Giorgos,
The link you have posted semms to be broken, I've gone even in the root http://www.atmel.no/beta_ware/, but no way.
Have a nice day
Pippo
the link works, I just downloading it with no problem.
Hi Pippo.
The link is still alive for me. I guess there is a DNS issue for your node.
A possible workaround would be to delete your internet cache (ie. temporary internet files), and try to reconnect to the root http://www.atmel.no/beta_ware/
If this does not work for you, I guess you will have to wait a couple of days, until your ISP proxy updates its own DNS cache.
No, the link was dead for a while (at least around 08:00 GMT), but it was alive and well less than an hour later.
I was not aware of that.
Thank you Johan.
The reason for this is that we had to do a minor update.after the initial upload. The observant user will notice that the version available now has build number 451. (the text on the website is still not updated but the software is).
Edit: The latest build number is now 452. Most users having downloaded 450 or 451 don't need to update (see release note on download site).
Please bear over with us. After all, we haven't announced this software being available yet (but soon will).
roland
It is OK Roland, I will update this thread's title.
Thanks for your effort,
Giorgos.
Does anyone know who is providing this plug-in? Atmel or Micrium?
Schimmi
The plug-in is developed by Micrium on Atmels request. It contains full kernel awareness when debugging applications based on the uC/OS-II micro-kernel.
The plug-in will be available through the normal Atmel AVR Tools sales channels. It will be sold as a kit containing the Micrium uC/OS-II textbook, a CD-ROM containing the source of the kernel and an additional CD-ROM containing kernel ports for ATmega2560 and other AVR controllers as well as the AVR Studio plug-in. I think the recommended resale price for the kit will be $69, and it will be available within 2-3 weeks.
More information will be available at www.atmel.com and on this forum soon. It is a nice kit both for learning more about real time kernels as well as doing serious development and debugging. The combination STK500/503/JTAGICE mkII is a good set-up for exploring the capabilities of the kit.
$69 gives you all you need for developing FW based on uC/OS-II. For use in commercial applications there is a one time royalty fee for each product, collected by Micrium.
Regards Dag @ Atmel.
Is this "AVRISP mkII" going to obsolete all the existing AVRISP programmers?
Are we going to be stuck in the same rut with the existing AVRISP programmers as we are with the mature JTAG ICE? (ie. no support for new devices unless you shell out the moola for a new mkII programmer, even though the target-side hardware interface is identical?)
file wont completely download for me.
I've tried 3 different browsers/ftp clients and 3 differnet computes..
goes to 98-99% percent and freezes..
has anyone mirrored it yet?
This is an unregistered version of Bullet Proof FTP V2.45.  You have 30 days left to evaluate it.
It is not crippled in any way, it will just stop working when your evaluation period is up.
Use Help|Purchase to purchase BPFTP, which will enable you to use it after the 30 day period.
URL detected in clipboard.
Connecting to www.atmel.no port 80
Requesting http://www.atmel.no/beta_ware/as4/b450/AvrStudio4Setup.exe
HTTP/1.1 200 OK
Date: Mon, 03 Oct 2005 18:45:53 GMT
Server: Apache
Last-Modified: Mon, 03 Oct 2005 12:55:26 GMT
ETag: "29c7442-2d4ac1f-43412a3e"
Accept-Ranges: bytes
Content-Length: 47492127
Connection: close
Content-Type: application/octet-stream
X-Pad: avoid browser bug
Downloading http://www.atmel.no/beta_ware/as4/b450/AvrStudio4Setup.exe
Server closed control connection.
46,967,456 bytes transferred in 00:07:27, 105,072 bytes/sec
Delaying for 10 seconds before reconnect...
Reconnecting - try #1
HTTP/1.1 416 Requested Range Not Satisfiable
Date: Mon, 03 Oct 2005 19:07:12 GMT
Server: Apache
Content-Length: 0
Content-Range: bytes */47492127
Connection: close
Error retrieving file.
Data Connection closed
hmm i ran the incomplete file i had and it installed correctly.
Is it true that this version has a built in gcc compiler?
From the original post:
No, not quite but almost. From the release notes for this version of AVR Studio (also quoted in the first post in this thread):
What this means is that AVR Studio can control the AVR GCC compiler. You can edit Your source files in Studio, You can control project settings from within Studio (no need to edit any makefile manually), You build Your application from within Studio, You run Your app in the Studio simulator, and You program Your app into the target AVR from studio (given that You have programming hardware that Studio can control).
The AVR GCC compiler does not come with Studio. You'll have to get that separately. The good news is that it is free, and that You can download an installation package from here. The thing You should look for is the WinAVR package.
Download WinAVR and install it. Install the new Studio. Create a new project and select "AVR GCC" as project type and Youre flying.
JohanEkdahl wrote:
it just worked!
It must be that the alpha testers did a good job.
Don
Looks like I got the AVR bug at just the right time!
Now I will download this and try programming the things using gcc.
update:
Well, I went and got this and installed it..it works.
I typed in a c program and got it to compile and simulate.
Heck, this is all I need right here...why spend good money
on a C compiler when this works so well.
I used the first c program from that book "C programming for Microcontrollers" I commented out the delays so it would run
fast in the simulator.
it runs fine after fixin up a tiny flaw. (i <= 128 should be i < 128 otherwise bit 7 lights up twice as long as the rest do)
// Blinky.c
#include
#include
int main (void)
int i;
DDRD = 0xFF;
for(i = 1; i < 128; i = i*2)
PORTD = i;
// _delay_loop_2(30000);
for(i = 128; i > 1; i -= i/2)
PORTD = i;
Ah... Cool! I missed that, it would light LED 7 in the loop interation when i == 64 and the i*2 makes it 128, and then it would continue to light it in the next loop interation because i == 128.
Smiley
**PANIC MODE ON** which AVRISP mkII are you referring to? :-)
This kicks so much butt. Yay for Atmel, finally.
It's a mighty small flaw there smiley, I would not have noticed it
had I not single steped it out on the simulator.
Hi John.
The USB ATAVRISP mkII, the successor of the well known $29 ATAVRISP.
It has been anounced for the Q4 of this year. Here is a picture of it https://www.avrfreaks.net/index.p... from the AVR Studio 4.12 help files.
I do know anything more...
Giorgos.
EDIT: Of course I meant to write "I do not know anything more..."
Well....a bit more relaxed now...it may just be a ATAVRISP with a built in USB adaptor chip in it...or so I hope :roll:
Yeah, small flaw, but what kind of fool has an error like that in a book on C programming?
Oh, wait a minute...
Never mind,
Smiley
Smiley - it's not a flaw but rather an exercise for the student to identify the error.
Don
While it sounds that stuff should 'just work', it doesn't for me. I'm a newbie at winavr and working with smileys book to get going.
However, I've got blinky working using winavr/programmers notepad without a hitch, straight sailing. My butterfly is blinking away as I type :-). Simulation does work fine too, loading the coff file into AVR studio.
I then created a new gcc project in AVR Studio (in a new directory), copied blinky.c over and added it to the project. When I hit 'build' it goes off and starts to build and display the following errors:
rm -rf Blinky.o  Blinky.elf dep/ Blinky.hex Blinky.eep Blinky.lss Blinky.map
Build succeeded with 0 Warnings...
avr-gcc -I"C:\WinAVR\include"  -mmcu=atmega169 -Wall -gdwarf-2           -O0  -funsigned-char  -funsigned-bitfields  -fpack-struct  -fshort-enums  -Wp,-M,-MP,-MT,Blinky.o,-MF,dep/Blinky.o.d  -c   ../Blinky.c -o Blinky.o
../Blinky.c: In function `main':
../Blinky.c:16: error: 'for' loop initial declaration used outside C99 mode
../Blinky.c:22: error: redefinition of 'i'
../Blinky.c:16: error: previous definition of 'i' was here
../Blinky.c:22: error: 'for' loop initial declaration used outside C99 mode
make: *** [Blinky.o] Error 1
Build failed with 5 errors and 0 warnings...
Markus
Markus
This seems to indicate that You are using an old version of WinAVR (as the recommended debug format has changed from COFF to ELF/DWARF). What version of WinAVR are You using?
Could You please post (attach) blinky.c exactly as it looks when You get the above errors?
As far as I know my version of winavr is the most recent (20050214).
Here my blinky.c (cut & paste out of studio):
// Blinky.c
#include
#include
void wait(void);
int main (void)
	// set PORTD for output
	DDRD = 0xFF;
		for(int i = 1; i <= 128; i = i*2)
			PORTD = i;
		for(int i = 128; i > 1; i -= i/2)
			PORTD = i;
- The above blinky.c was copied from smileys CD
- The same file works file with winavr
Markus
Markus
Markus,
You'll save some brain cells if you do as I recommend in the book and use only the older versions of the software available on the CD and on the website. The new stuff is great, but it is hard enough to learn C on the Butterfly without adding to it trying to use different tools. I'd recommend that when you finish what you want from the book and the old software, then archive it somewhere safe in case you need to return to it, then download all the latest and greatest stuff to play with.
Smiley
Hi Smiley,
I'm fully aware of the time I loose and the risks I take by using bleeding-edge release candidates. I'm going forward in my c learning excercise using the nicely working winavr toolset.
Using only one tool however (AVR Studio) for everything is worth trying for me as I have not yet invested a lot in something else. In addition reading this very thread seened to indicate that it works. So I give it a try.
Markus
Markus
The C standard has gone through many revisions through the years. Once upon a time, it was illegal to declare the counting index of a for() loop inside the loop declaration itself. That is, you could do:
int i;
for(i = 0; i < 10; i++)
but you couldn't do:
for(int i = 0; i < 10; i++)
A newer version of the standard (C99) will allow that construct: the counting variable i would have to be previously undeclared within the scope of the function, and after the end of the for() loop i would cease to exist again.
avr-gcc can be tweaked at compile-time to adhere to different sets of C standards, according to the user's preferences.
The default makefile that you will have used with Smiley's book included options to turn on C99 support. The makefile that AVR Studio generates apparently does not enable C99 standard support.
I'd suggest that you aren't doing anything wrong; looking through the Configuration Options dialog box, it's clear that right now AVR Studio doesn't include an automatic way to define the C standard level; it is possible to add a custom flag in the Custom Settings tab, but a beginner shouldn't have to know that.
IMHO, this is a shortcoming of this Release Candidate, and that hopefully the final release won't suffer from it.
In the mean time, you could tweak the C standards support manually, or else you could make some trivial changes to the source code so that it adheres to a previous standard, or else you could do as Smiley says, and stick with the tools that are supported by his book.
- Luke
Ah, I see. Its not a problem with AVR Studio as such. Smiley has written code that demands that the compiler works with the gnu99 standard, and Studio does not set this up by default. The code that causes the problem is
The compiler does not like that You define i in the control block of the for statement. You can solve this either by moving the definition of i outside the parenthesis
int i;
for(i = 1; i <= 128; i = i*2)
or by setting the -std=gnu99 option for the project. To do this:
1. In the Project menu, select Configuration options
2. On the left, click Custom options
3. In the field just to the left of the Add-button, type -std=gnu99, and click Add. (What You typed should be added in the list above where You typed it).
5. Exit the dialog with OK and rebuild.
Better?
Edit: Beaten by lfmorrison once again. Still, theres seems to be other stuff that prevents use of the c99 standard for this program, so stick with -std=gnu99!
Hi Luke,
moving the definition of i outside the for statement as you suggest makes my blinky compile !
If I add -std=c9x to the custom conguration options it work also. (Yup, I've been reading gcc docs in the meantime).
Hovever I've compared the CFLAGS used by Studio with the CFLAGS in the makefile and they are the same.
Markus
Markus
I saw the post about the new avr studio release and, as it can
be used as IDE for winavr could not resist.
Everything seems fine, but when, after compiling, I upload the
code to the ATTiny26 on the STK500 with "Use current simulator
flash memory", the upload takes a fraction of a second: not good
(and it doesn't work...). There is also no error message of any kind.
When uploading the generated hex file with "Input Hex file",
it functions properly.
Any ideas ?
Geert
In the Project Options dialog for a GCC project, I've added [Linker Options] in the Custom Options tab.
The linker options I've added are:
--defsym=spp_start=0
--section-start=.text=0x1800
However, these options don't get passed to the linker. I had to modify them as follows for them to work:
-Wl,--defsym=spp_start=0
-Wl,--section-start=.text=0x1800
I have two requests relative to Custom Options:
  1. Allow for editing of options
  2. Make the option list window wider and/or horizontally scrollable
Don
Don.
I have implemented your requests 1 and 2. Unfortunately, the changes did not make it into rc2.
(No horizontal scroll yet, but the option list window has been made wider.)
Torleif
hello,
i recently installed v4.12rc1 and experieced that it is much slower in building up the source windows and reacting on mouse click then v4.10 i used before.
for example after stopping execution in v4.10 the source windows was updated within 1 second, with v4.12rc1 it tooks more then 10s.
does anyone else have the same behaviour?
if not what could be wrong?
regards
gerhard
I see a big and wonderful bug, while trying out RC1 (450):
See to it that the insertion point is in a source file. Select any menu with Alt-[/i]character[i] (eg. the project menu with Alt-P). Now, when I try to step through the manu alternatives with the down arrow, the insertion point (caret) is movng down in the source window.
At first it looked like the menu has no keyboard focus at all, but that's not the case. When the menu has been opened You can do selections in it by typing the underlined character in the alternatives. It's only the arrow keys that don't work.
I have a vague mmory of having sen this before in earlier versions, but I'm not sure. What astonishes me is that such an obvious bug has gone by unnoticed / unfixed. Am I the only one seeing this?
This is an issue we know about, but have some problems fixing.
It might be a conflict between different libraies we are using for the editor and the framework.
Anyway, a quick workaround is to keep the Alt depressed while navigating with the arrows.
Lars Kvenild
Atmel Norway
New program update: 4.12.453 RC2. Get it from here: http://www.atmel.no/beta_ware/
Giorgos.
It look this release still does not correctly show flash or eeprom variables in the watch list, though simulation of a program with eeprom and/or flash variables work.
A flash or eeprom variable is displayed in the Watch window as location "SRAM" with an invalid value.
Hello Everyone!
I just Installed RC2 and I am not able to create a new project using the gcc plugin... What I am doing is creating a New project, and follow the wizard instructions and when I press finish button, it display a windows error message closing avrStudio.
Does anybody have the same problem?
Alex
ARod
Hi. A few minor malfunctions of the AVR Studio 4.12.453 RC2. My OS is WinXP SP2 on a Prescott machine.
The program does not always save the projects, either they are Assembler or GCC type ones. It seems that it cannot always detect when a project has been changed (ie. add/remove project files, brake-points, or watch elements).
Additionally, the source code bookmarks are not saved at all, even if the projects are forced-saved.
Opening the *.aps project files with Microsoft XML Notepad though, the latter always finds them to be "well formed" and is also able to successfully edit them.
Giorgos.
Every once in a while a bug pops up in released configuration managed software. Still want to go for a shuttle ride?
Hello everyone,
After few trials and errors I found the bug, and In fact is in RC1 and RC2. everything is related to the option for "auto open last project" in the options window. you can go to Tools->Options.. menu and then "General" and check/uncheck that option; the easy way to know that something goes wrong is when you close avrStudio and open it again. you will see in the message dock section the following:
Loaded plugin STK500
is not a AVR Studio 4-savefile (with a red dot)
After unchecking that "feature" I was able to create any project using avrStudio. I hope this helps to kill bugs in the forthcoming RC3?.
Alex
ARod
I hve done it over,Thanks .
gerhardf wrote:
hello,
We have seen this problem when the project lives on a network drive, particularly if there is a large number of source files in the project.
Moving the entire project directory to a local drive should work as a temporary workaround.
We are working at this.
Roland Kruse
Atmel AVR Tools
rkruse wrote:
gerhardf wrote:
hello,
Roland Kruse
Atmel AVR Tools
hello roland,
i can confirm that moving the entire project directory to a local drive made things faster but it is still slower than v4.10
regards
gerhard
Gerhard!
Open up a project sitting on a networked drive, and do nothing more. Now take a look at the LED indicating network activity on Your NIC. Mine is blinking like hell. Open up the status dialog for Your network connection. Mine is showing something like 250 packets sent and 250 packets recieved per second! And it wont stop.
Close the project (not Studio, just the project). It stops.
My setup: Studio 2.12 RC1 (450) on Windows XP Home edition. (But I have seen similar behaviour on W2K pro). Server is running RedHat Linux 8, and Apache (not sure of version right now).
Edit: OK, the server is running Apache but that's totally irrelevant for the problem at hand. It is running Samba though (still not sure of version).
hello johan,
i can confirm your observation. LED on NIC is blinking like hell as soon as i open a project.
@roland:
any idea when this problem will be solved?
regards
gerhard
gerhardf wrote:
hello johan,
@roland:
We are working on it. We believe the performance problem and the network activity you see are related., but we are not yet entirely sure what operations cause this activity.
We hope to have a solution before the week-end, but I cannot guarantee that. I expect we will put out a new RC as soon as we have a solution that seems satisfactory. The only thing I am absolutely certain of is that we will not release the final version of 4.12 before this is fixed.
Update: We have solved the network activity issue, but still working at the performance issue. It turned out they are completely unrelated.
roland
Hi dear co-freaks.
Another Release Candidate, the v4.12.454 RC3, here: http://www.atmel.no/beta_ware/
Let's give it a try!
Fixes in build 454:
Giorgos.
On updating to 4.12 I see that the change to smart docking comes with a sting in the tail.
The Output and Workspace views are now composed of a number of independantly managed windows. As a result trying to change the views can be troublesome.
If for example I wish to hide and later unhide the Workspace view, previously done by toggling a tool bar icon, I need to hide each individual tab window and then use the View menu three times to recover them. Very cumbersome.
Toggling these views on/off is something I do quite regularily. Either to free up screenspace or when opening a new file the scroll bar always hides under the Workspace view ( for some reason the new file always opens twice the width it should be).
It would be good to get toolbar control of these views back.
I also see that it is no longer possible to open more than one version of a file. This is of course much safer. It would however help if when the file view was split horizontally there were scroll bars for each part of the split.
Have a serious performance problem with RC3 (also had this on RC1). 8 c-source files, 7 header files and about 20 External dependencies.
All worked fine until a certain point where compilation/linking suddenly started taking 15-20 seconds instead of 1-2 seconds. The GUI will freeze up during this and also the output in the build window is erratic.
First time this happened, it was after I had added some calls from the main code to functions in one of the other c-files. I tried commenting them but it was the same. I restarted the GUI and removed the comments, and everything was ok again. Have tried all variants now, but no matter what I try, it's still the same problem.
It seems like some kind of resource problem. Not on my PC though, it worked perfectly yesterday with about 17 other open programs some of which was very CPU and resource intensive. Now after the code has grown, it won't even run properly alone.
This project will otherwise compile all files in < 1 second from the command line with a regular makefile.
Also, when this happens, I cannot enter (JTAG) debug mode at all, the program will just hang. Once it actually started debug, but that was after several minutes.
Others with the same behaviour ?
/Jesper
http://www.yampp.com
The quick black AVR jumped over the lazy PIC.
What boots up, must come down.
I donwloaded multiple times on friday night, but I wasn't able to install it, the Installer said that some files are corrupted. I will try today to see if the installation process goes peaceful.
ARod
Thanks for the notification. I'll update the thread's title.
I am downloading it now.
Done!
RC4 downloaded and installed.
I do not know why, but the installer needed to restart the machine (WinXP SP2 on a Prescott), afterwards.
It seems to be all right, and I think that the simulator runs a little faster.
An older silly bug though, still exists: Studio still does insert randomly placed bookmarks.
Further testing in progress...
Giorgos.
Jesper,
The avr-gcc plug-in does some parsing of dependencies when building a project.
There is probably an error somewhere in this parsing routine.
Would you consider sending your project to avr-beta@atmel.com so I could have look at it?
Torleif
Torleif,
I have found out why the compile process was slow. It was due to a USB card reader being connected (and accessed).
When I disconnected it (it's mapped as drive M, standard windows mass storage drivers), all worked fine again.
If I connect it, there's no problem until I've had a card in the reader and accessed it, but then compilation again is extreeemely slow.
Note that this card, the path and the files are completely unrelated to the actual project in AVR-studio.
There's still something rotten about the debug. After I found out about the USB drive thing, it's better, but it still locks up, or is very slow to start sometimes. As soon as it starts loading code to the CPU, it's okay though.
I'll test some more and post the results here.
/Jesper
Jesper,
Thanks for the clarification!
Does the USB card reader use much CPU when accessing cards?
This could (of course) slow the build process.
When do you still experience lock-ups? Is it when you are loading an avr-gcc project, or building a project? Is AVR Studio using much CPU when this happens?
Torleif
Jesper / Torleifs,
The M: thing is a well known problem ni avr-gcc - no doubt EW will be a long in a minute to explain it in full detail but the avr-gcc.exe has an M: path "burnt in" as a place to look for files. As long as you don't have an M: on your machine it just ignores this and steps on to look in other places but if there is either a network M: or an inserted memory card appearing as M: or something then you hit this problem. It is not a problem in Studio as such.
If you load avr-gcc.exe into a program that can pull out the ASCII strings you will find, embedded in it:
m:/WinAVR
m:/WinAVR/bin/
m:/WinAVR/lib/gcc/
m:/WinAVR/libexec/gcc/
m:/WinAVR/share/locale
which I think was the directory structure on the machine where avr-gcc.exe was built in the first place.
Cliff
The operation of my JTAG ICE2 programmer has changed since updating from 4.11 to 4.12 RC3. Before I could leave the programming dialog open, program a device, power off, connect another AVR, power up and program etc. Now I get a "JTAG Mode Error" when I try to program the next device, and the only way to resolve this is to close and then re-open the programmer dialog every time the target power is cycled.
A second issue is that the JTAG ICE holds the target in reset after programming until I either cycle the target power or disconnect and reconnect the JTAG ICE from the target. Very annoying when you are frequently re-programming during heavy debug sessions. This never happened with the old serial JTAG ICE under 4.11 (can't remember if this was the case with the mk2 under Studio 4.11).
I have just updated to RC4 and updated the JTAG ICE firmware, but the behaviour is still the same. Has this been changed deliberately or is it a bug?
The target in all cases is the Mega128 running at 3.3volts.
Currently using RC3:
Found that when I highlight a variable and I start draging with the intent of dropping into the watch window, the source code file tabs jump when my mouse curser moves over them.
Any chance this can be fixed? It's really annoying to be forced to highlight then right click to select Watch:Variable.... It is so much faster to drag/drop the variables into the watch window.
Oh and I second MikeRJ's request above regarding programming with the JTAG mkII. I believe the problems all started with V4.12 (all RC's). Very annoying to be forced to remove the JTAG to free up the reset line....
Thanks!
Monsoon
clawson wrote:
Jesper / Torleifs,
m:/WinAVR
m:/WinAVR/bin/
m:/WinAVR/lib/gcc/
Cliff
Ok, so I'm a day late. (There's a lot of posts to go through and I don't check this forum often).
Yes, Cliff is essentially correct. The only technical nit is that it's not where GCC is built, but where it is *installed* after it is built. That installation directory is specified when you configure GCC ("configuration" is the step before you actually build the software). That installation directory is hard-coded into the GCC executable as the place where GCC will look for other components (programs) that it will call on compile. If GCC does not find the components there, only then will it look on the PATH environment variable. This characteristic is due to the Unix nature of GCC, where it is expected that everyone builds GCC for themselves and it doesn't necessarily get redistributed. On Windows, however, it is common for the executable to be built once and then redistributed to various machines that may have different setups.
So, yes, this is a known issue. I submitted a bug report on it awhile back to the GCC team. No, AFAIK, nothing has been done on it. Yes, I do have an idea for a workaround, but it hasn't been tested yet. Yes, the reason why I haven't tested it yet, is because I haven't done a new WinAVR release. Yes, the reason why I haven't done a new WinAVR release yet, is because I've been incredibly busy with moving and a new job. Yes, some of you may already know where my new job is, for those of you who frequent the avr-gcc and avr-libc mailing lists. And for those of you who don't know, or anyone for that matter, please feel free to contact me at my (relatively) new place of employment:
eweddington@cso.atmel.com
Eric Weddington
Sr. Software Engineer
RF & Automotive Applications Group
Atmel Corp.
(Colorado Springs, CO, US)
And, yes, AFAIK, WinAVR will continue to exist (really, it's on my high priority TODO list to get out a new release, just after the current high priority task I'm working on...), and no, Atmel does not officially own WinAVR.
I hope that clears up a few things now.... :)
Well here's an idea which might help Jesper (and anyone else in this situation).
Using the 'dos' subst command, create a virtual m: drive pointing to the directory above your WinAVR directory.
GCC can then use the m: drive (and avoid working through the path environment variable), and when you plug in your usb drive, it will be forced up to the next available drive letter.
HTH.
Colin
Atmel Corp.
Just to say congratulations on the new appointment.
Cliff
Thanks for the info. I'll update the thread's title.
Found another bug (build 456).
When I start AVRStudio and open a project, the source windows that was open when I closed the project the last time is moved down and to the right (like when you open multiple windows in a MDI app in Windows). They're soon about to reach the edge, and I really wonder what will happen then ;-)
So, it seems the window positions is not restored correctly.
/Jesper
The Breakpoint Option "Continue Execution after the Views have been
updated" does not work, even in the Simulator.
Martin
The AVR-GCC does not correctly define the -DF_CPU=xx as in the WinAVR Makefile
The frequency specified in "Project Options" in Hz should be passed with UL:
e.g. Frequence in Project Options: 4000000 hz
is passed to build window as:
-DF_CPU=4000000, but should be -DF_CPU=4000000UL
This is required to pass the frequency as a 32 bit value to the compiler
The only work-around is to edit F_CPU using Project Options -> Custom Options
According to the comments in the WINAVR makefile_template file:
Do NOT tack on a 'UL' at the end, this will be done automatically to create a 32-bit value in your source code.
Don
That's simply because MFile's makefile template defines the constant passed to the compiler as CDEFS = -DF_CPU=$(F_CPU)UL. This is the meaning of automatic...
Bye. Carlos.
Carlos, you are correct - I missed that.
Based on what I learned from Carols' post, I agree.
Don
-projects don't autosave when buit anymore. Unless this is an option I had turned on in 4.11, I did not see it in the options of 4.12.
-labels can't be on the same line as .db (intended?)
-ADCSR was changed to ADCSRA for the tiny26 (intended?)
-sometimes when i come back from hibernate it says 'server is busy' and hogs up the cpu until i end program
-sometimes when i open a project the individual files are there in the tabs but not there in the workspace. Clicking on a tab does not bring up anything.
In the Memory Window Is is possible to preserve the memory type and the start address of the window.
I ahve three windows where I monitor memory contest . iteral ram, and twop external ram buffers.
The porblem is that AVRStudio does not preserve the m,emory type nor start address.
Can this be added please
Kind Regards
Ivan Vernot
This is for me the most anoying bug, i lost half an hour searching why the latest software changes didn't work :-(
Cannot uninstall!!
After successfully using 4.12 (build 460) on two PCs, one with Windows XP Pro (not Service Pack 2) and one with Windows 2000, I installed it on a PC with Windows XP Pro Service Pack 2, IE version 6. I ran into problems with JTAGICE not being recognized (will post separately about these, when I get exact message wording) and attempted to uninstall.
When I try to uninstall (click the Remove button in Control Panel), the screen flashes and nothing else happens.
I tried uninstalling on my other PC with XP Pro and it started to uninstall properly (I responded "No" to confirmation).
One difference is that 4.12 is the first version loaded on the problem PC. On the others, I had previously loaded 4.11 and (contrary to Atmel's advice) simply installed 4.12 over that.
Any ideas?
Thanks in advance.
Michael Bate
A watch bug.
(maybay already mentioned before, I didn't follow this forum for a while, sorry if so)
When using a multidimension variable, like char i[2][2], the watch window doesn't show correct info, see attached image.
Jan Pieter de Ruiter
With 4.11, after downloading the code, emulation was stopped at the begining of the program waiting for me to hit F5 to start. With 4.12 after downloading execution hits the ground running. Also the debug/reset function causes execution to restart, even if pressed AFTER hitting break. This is bad.
Work-around is to hit break and set a breakpoint at the first line in my program.
I made my own toolbar (Tools -> Customize... -> Toolbars -> New).
Next time I started AVRStudio 4.12 I had two of these own toolbars.
Then 3, then... AVRStudio didn't start anymore, just a window reporting an error.
So I downgraded back to 4.11 + sp3 (this is now second time).
Also commonly it was more like lottery what did the desktop look like after almost any operation.
(Yes, I noticed that this version has different priciple in storing desktop settings, but still...)
Once it looked like AVRStudio started, but every operation with mouse was directed to the
underlaying Windows desktop, and some desktop icons appeared thru holes in this "image"
of AVRStudio.
I don't complain, it's a free tool. I just hope it gets fixed, looks otherwise attractive.
I use Windows 2000 + SP4, P4 and Radeon 9200
Disclaimer
There is no warranty for this text.
I provide this text "as is" without warranty of any kind.
In no event will the writer, be liable to you for damages
Trademarks
Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries.
A list of Atmel's registered trademarks may be obtained from any publicly accessible patent database, subject to the limitations or restrictions of such databases, if any.
New AVR Studio update.
AVR Studio 4.12, Service Pack 1, build 461.
Get it here: http://www.atmel.no/beta_ware
