Add New Class feature
4 posts / 0 new
When I create a new class using the "Add New Class" tool, select class and give it a name (eg. A), I get these lines in the header file:
private:
    A( const A&c );
    A& operator=( const A&c );
What do these lines actually do?
I have 2 classes (defined using Add New Class), and if I want to return class A from a function in class B, it throws an error because of these lines.
Error is:
B.h:In file included from
B.cpp:from
A.h:In member function 'A B::getA()'
A.h:38:2: error: 'A::A(const A&)' is private
:A( const A&c );
B.cpp:81:9: error: within this context
:return waveform;
Error compiling
Goes away if I comment these lines out.
cheers
Paul
These are copy constructors (that's the google-worthy term). I'm not going to re-iterate much about these, but they basically means that you will not be able to copy objects of this class (through assignment, =, or construction)
:: Morten
Ehhh. be very very careful of copy constructors!
Temporary objects are NOT your friend!!
I put the little buggars in private and leave them unimplemented so they cannot be called
Keith Vasilakes
Firmware engineer
Minnesota
Thanks for the info.  Will do some research on copy constructors!
