Searching for a Cap!
12 posts / 0 new
Hello 'Freaks,
     I am repairing an ultrasonic cleaner and I am struggling to find a capacitor (.512uF 2000v film) with the marking CBB81-512J2000V (see pic)
I am trying to go back with original equipment - I found all the others on ebay (exact replacement), but I guess I will have to substitute this one...
Am I being ridiculous by trying to go back with the exact same part? I only found two bad ones, but while I have it open I was going to replace all of them...I have found all but these two on ebay for less that $10 US total!
John
Just some guy
Where do you get 0.512uF?
5100pF is more likely, especially for a Film Capacitor.
Take a look at this one.  Notice the 562J in the part number for 5600pF = 0.0056uF.
You're right Chuck!! :-/
Just some guy
2000V?
Yes, 2000 volts is the rating
Just some guy
Whats the transducer in an ultrsonic cleaner? A crystal? You charge up a cap and zap the crystal and it gets bigger or smaller or something?
The small ultrasonic cleaners I've seen all used piezoelectric crystals, although I'm sure other approaches exist.
If one physically deforms the crystal, (either with a sound wave, or a hammer), it generates a voltage.
If one applies a voltage across the crystal, it deforms the crystal, generating motion, and hence a pressure wave.
(In this case the crystal is usually connected to a diaphragm, think of an old fashioned "crystal microphone", used backwards.)
The two common ways to generate the ultrasonic signal are to apply a drive signal to the crystal.
The drive signal can be set to the crystal's resonant frequency, so you get a continuous and good size physical vibration in the crystal, or one just applies a big voltage pulse to the crystal, to deform it, and it will ring at its resonant frequency.
Perhaps a material science engineer can chime in, (any of those on Freaks?).
I think the limiting factors on the ultrasonic cleaner are both the electrode bond to the crystal, and the destruction of the crystal by its internal (shear ? ) forces with higher drives.
Last Fall I spent a little time trying to measure the impedance of a small ultrasonic transducer as a function of the applied frequency.
I clearly wasn't doing it like the manufacture's set up.
My results didn't generate the nice graph in the data sheet...
I did, however, see several mini-resonant frequencies, from say a longitudinal wave vs a transverse wave in the crystal.
Very interesting, but not what I was after.
The real question for John, of course, is why did the caps fail?
Old age, dried out, etc?
Or under spec'ed for the application?
 I am unsure - the 2000 volt ones (there are 3) did not fail. I had one fail on each board - there are three transducers epoxied to the bottom of the tank and they each have their own supply.  I replaced the blown capacitor on one supply and that transducer came  back to life.
This is for a friend who uses it to clean carburetors from Mercury boat engines - the passages are so tiny that he needs to use the cleaner. My hunch is that they ran the unit without fluid and caused the caps to fail, but I have no way of knowing. I simply wanted to replace all the caps as a precaution.
@Chuck99 - thanks for the link - I wonder why they don't offer the 512?
John
Just some guy
Digikey doesn't stock the 5100pF but Mouser does.
Mouser Part #:              667-ECW-H20512HV
Manufacturer Part #:    ECW-H20512HV
Manufacturer:                Panasonic
Description:                   Film Capacitors 0.0051uF 2000VDC 3%
Pricing (USD)                  1:  $1.01
Thanks Chuck!!
Just some guy
Can't go wrong with this one:
Lyrics
I Love My Green Bay Packers
(The famous Packer Polka!)
©1993 Words and Music By
Edward J Lemberger
Esayian Publishing (BMI)
Tell all the people across the USA
I love my Green Bay Packers
Who won the first Super Bowls ever played
Pity Chicago, Detroit and Tampa Bay
They all come up as lackers
We take our opposition
And crunch 'em like they're crackers
That's why I love my Green Bay Packers
Tell that Rush Limbaugh
Tell Hillary and Bill
​I love my Green Bay Packers
Tell Willard Scott. Tell Oprah and Phil
​I'll bet even Ditka's a secret Packer Fan
He knows the best shellackers
So if you're green with envy
Wear Gold they're perfect matchers
Bup bah da bup bah da bup bah da bah
Bup bah da bah da bup bup bah da bah
Don't take this wrong
But compared to old Green Bay
You're just a bunch of hackers!
Yes, we take our opposition
We got the best team
Go Pack!
laugh
Eddy J's site: "Singer, songwriter, certified hypnotherapist" lol
Eddy also has a lot of <br>'s on his home page!! haha
Just some guy
