Isn't AS 6.2 insanely large?
5 posts / 0 new
Installing/reinstalling AS on some computers I chose to make sure I get the latest 6.2 SP1; after starting the environment I noted how long that took loading, but at first I just thought it related to a "first start syndrome".
Now, every time I start it, appears to be unreasonably slow (from a user's perspective). Checking its memory footprint, I see it takes around 570 MB (plus 21 MB for atbackend.exe) with no project loaded - sheesh!
frownDid anybody else find it to be a bit overweight as I do?
Don't have at hand a VS 2012/2013 instance to compare (maybe they are comparable?), but a humble VS 2010 runs at 135 MB, in a very shorter time.
~Lou
AS6 is VS2010 so you'd expect performance to be similar though it's true that Atmel bring a lot of baggage and it seems they load/precache a lot of it during startup.
and have you compared this to Eclipse... ?
Well, I didn't: usually I'm not using Eclipse, when not being suggested by a gun at my head.
However, I can tell the results I get (along with such kind invitation) with a Xilinx/MicroBlaze project I'm running, on their Platform SDK. Launching that project (a few tens on thousands lines of code, and a few tens of source files) accounts for around 280-320 MB of private bytes, used by the IDE. AS -sigh- still wins.
~Lou
VS 2010 with large web site solution loads 119K in ~10secs
VS 2013 Community Edition with a minimal solution loads 102K  in ~15sec.
AS 6.2 with minimal solution 438K and loads in ~30secs (hung first time I tried to load)
Happy Trails,
Mike
JaxCoder.com
