How To Stop Timer0 in ATmega8.
4 posts / 0 new
I am try to measure distance via HC-SR04 ultrasonic sensor module.
first im send a 10us pulse in HC-sr04 trig pin,
then checking echo pin..
when echo pin go high then start Timer0.
now im stop the Timer0 when echo pin go low.
please suggest me how to stop timer0.
(I am skip Timer Overflow interrupt)
শূন্য  - The ZeRo
TCCR0B = 0;
But really you don't need to stop the timer, you only need to capture the value of it by reading TCNT0:
foo = TCNT0;
If you started with the timer at 0, then foo will contain the number of ticks which timer 0 counted before you captured TNCT0.
I misspoke :(
ATmega8 doesn't have TCCR0B, it only has TCCR0, so:
TCCR0 = 0;
... will stop the timer.
Perhaps you should post your code.
//first im send a 10us pulse in HC-sr04 trig pin,
//then checking echo pin..
   loop_until_bit_is_set(port,echopin);
//when echo pin goes high then clear Timer0.
   TCNT0 = 0;
//when echo pin goes low then read Timer0.
   loop_until_bit_is_clear(port,echopin);
   value = TCNT0;
