Atmega8 Multiple ADC and display it
5 posts / 0 new
i'm struggling to read/display 4 ADC port.
#include <avr/interrupt.h>
#include "lcd.h"
#include <stdlib.h>
#include <stdio.h>
char v[7];
	lcd_init(LCD_DISP_ON); /* initialize display, cursor off */
	lcd_clrscr(); /* clear the screen*/
  ADCSRA |= (1 << ADPS0) | (1 << ADPS2); // Set ADC prescalar
  ADCSRA |= (1 << ADFR);  // Set ADC to Free-Running Mode
  ADCSRA |= (1 << ADEN);  // Enable ADC
sei();
ADCSRA |= (1 << ADSC);  // Start A2D Conversions
ISR(ADC_vect)
	uint8_t theLow = ADCL;
	uint16_t theTenBitResult = ADCH<<8 | theLow;
	switch (ADMUX)
		case 0b00000000:
		lcd_gotoxy( 7, 1 );
		dtostrf(theTenBitResult,4,0,v);
		lcd_puts(v);
		ADMUX |= 0b00000001;
		break;
		case 0b00000001:
		lcd_gotoxy( 0, 1 );
		lcd_puts(v);
		ADMUX |= 0b00000000;
		break;
		default:
		// no default
		break;
If i read one by one is working, but i cannot read more than one. at least on the display did not show anything.
	ADMUX |= 0b00000000; //ADC0
	//ADMUX |= 0b00000001; ADC1
sei();
			lcd_gotoxy( 7, 1 );
			lcd_puts(v);
My uC is Atmega 8 running at 1Mhz(internal clock) with external AREF 2.5V.
You are setting a prescaler of 32.  At 1 MHz, that will give you an ADC clock of 31.25 kHz.  The ADC is spec'd to run between 50 kHz and 200 kHz, so this is technically too slow.
This isn't responsible for troubles, though.
You've selected free-running mode.  In that mode as soon as one conversion is complete another is started.  So in your ISR this:
... has no effect as a new conversion is already under way.
More importantly the MUX bits are latched at the start of each conversion, so when you change them in your ISR you're actually changing them for the next conversion, not the one currently under way.
To be clear, you should turn off free-running mode. Also:
This does nothing. To clear a bit you need:
ADMUX &= ~0b00000001;
Steve A.
Koshchi wrote:
This does nothing.
Very good.  I'd stopped looking once I found the first error.
The to OP, as written your code will sample ADC0, and then forever ADC1.  Follow @Koshchi's advice.
Thanks for all your help! Now is working half but i still need to review the code..
I forgot to enable the ADC interrupt!
