AVR tool chain won't work for ATMega2560
2 posts / 0 new
Hi all,
I have built the AVR tool chain from sources on MacOSX and Sun Solaris (see below how). This used to work for ATMega8 projects. I purchased a ATMega2560 chip/board now. Replacing the the MMCU in Makefile with MMCU=atmega2560 did not do the trick. When I try to compile a little test program
#define F_CPU 16000000UL  /* 16 MHz CPU clock */
#include "Global.h"
#include <util/delay.h>
int main (void)
   DDRB = 0xff;          // all outputs
      if ((PORTB & _BV(PB7)) > 0) PORTB &= ~_BV(PB7);
      else PORTB |= _BV(PB7);
      return (0);
I get
main.c:1: error: MCU ‘atmega2560’ supported for assembler only
make: *** [toggle_led.out] Error 1
When I do "avr-gcc --target-help" I get
atmega2560
avr6  - enhanced AVR core with up to 256K program memory
listed. However, make produces
avr-gcc -mmcu=atmega2560 -Wall -O2 -I /usr/local/avr/include -I./ -o toggle_led.out main.c
unknown MCU 'atmega2560' specified
Known MCU names:
   avr2
a list with no avr6 or atmega2560 entry!? :-(
What am I doing wrong?
Thanks a lot,
 Andreas
We download http://ftp.gnu.org/gnu/binutils/...
    PREFIX=/usr/local/avr
    export PREFIX
    PATH=$PATH:$PREFIX/bin
    export PATH
    cd /usr/src
    mkdir avr
    cd avr
    scp ahoesch@192.168.1.7:/home/ahoesch/Downloads/binutils-2.24.tar.gz .
    gunzip binutils-2.24.tar.gz
    gtar xvf binutils-2.24.tar
    cd binutils-2.24
    ./configure --target=avr --program-prefix="avr-" --prefix=$PREFIX
    make
    make install
We download http://gcc.cybermirror.org/relea...
    cd /usr/src/
    gtar xvf mpfr-2.4.0.tar
    cd mpfr-2.4.0
    ./configure
    make
    make install
    cd /usr/src/avr
    mkdir avrgcc
    scp ahoesch@192.168.1.7:/home/ahoesch/Downloads/gcc-4.3.3.tar.bz2 .
    bunzip2 gcc-4.3.3.tar.bz2
    gtar xvf gcc-4.3.3.tar
    cd avrgcc
    ../gcc-4.3.3/configure --target=avr --prefix=/usr/local/avr --enable-languages=c --disable-libssp --disable-shared --disable-libada --disable-libssp --disable-nls --with-dwarf2 --with-gmp=/usr/local --with-mpfr=/usr/local --prefix=/usr/local/avr
    make
    make install
    pico /etc/default/login
    pico /etc/default/su
    PATH= ...:/usr/local/avr/bin
    SUPATH= ...:/usr/local/avr/bin
Relogin to get the new PATH value.
    which avr-gcc
We download http://download.savannah.gnu.org...
    cd /usr/src/avr
    scp ahoesch@192.168.1.7:/home/ahoesch/Downloads/avr-libc-1.8.1.tar.bz2 .
    bunzip2 avr-libc-1.8.1.tar.bz2
    gtar xvf avr-libc-1.8.1.tar
    cd avr-libc-1.8.1
    ./configure --host=avr --prefix=/usr/local/avr
    make
    make install
We download...
Sorry but why would you download such old and out of date code? Why not simply get:
http://www.atmel.com/tools/atmel...
That will give you a pre-built avr-gcc 4.8.1 and it most definitely works for ATmega2560.
