TQFP 44-pin PCB layout
10 posts / 0 new
Hi !
I need to draw PCB layout for ATmega324 uC and that is TQFP 44-pin.
I'm working with an archaic program PROTEL 99 which doesn't have this layout.
What I've found is
http://www.controlchips.com/qfp44dim.htm
I think this is OK.
Does ATMEL have some .pdf-s of recommended layouts for their chips?
Thank you !
Regards !
The layouts for their devices is located towards the end of the datasheet(s) for the deice(s).  Datasheets are in .PDF
Hey wash your mouth...  that was the last of the good Protel stuff. wink
I have used the TQFP 44 with Autotrax but I had to make my own component. Don't know if I can just export the component but I can give you a bit of PCB with the TQFP 44 on it which you should be able to import into SE.
Two minutes with Google ...
http://www.mikrocontroller.net/t...
In meiner Library habe ich unter anderen:
TQFP-44 (10x10x1) (z.B. fuer PIC18F4620)
TQFP-64 (10x10x1)
TQFP-64 (16x16x1)-0.8 (z.B. fuer ATMEGA 128)
TQFP-80 (12x12x1) (z.B. fuer PIC18F8722)
TQFP-100 (14x14x1) SOT-386-1)
Hopefully the PIC and AVR have the same footprint?
Also http://www.avrvi.com/avr_protel_... and http://bbs.ednchina.com/FORUM_PO... and others...
yes of course, but these are physical dimensions of chips. PCB layout should be a bit or two grater then given dimensions, like this one on last page:
http://docs-europe.electrocomponents.com/webdocs/121b/0900766b8121b405.pdf
I've designed at least 25 PCBs (you have probably done more then me) and all of them were soldered by hand, but I haven't use this package before and current design is going to be soldered by machine. So I think it might be a problem for positioning/soldering if I make layout for chip on my own way like I did it up till now (longer/wider pads..)
I think I've found what I was looking for :
http://www.maximintegrated.com/en/design/packaging/index.mvp?a=0&f=
http://pdfserv.maximintegrated.com/package_dwgs/21-0293.PDF
http://pdfserv.maximintegrated.com/land_patterns/90-0316.PDF
Shame that ATMEL doesn't have this  crying
Did you look at section 33. Packaging Information on the datasheet? I thought you wanted a ready made footprint not a PDF of the footprint.
Yes of course I had a look.
If  I've had a PDF of the footprint, than there's no problem to draw it wink
Thank you guys !
xtal_88 wrote:
... all of them were soldered by hand, but I haven't use this package before and current design is going to be soldered by machine. So I think it might be a problem for positioning/soldering if I make layout for chip on my own way like I did it up till now (longer/wider pads..)
Is this reflow, or wave soldering ?
I think ~ 0.8mm is where wave soldering can push to, and usually needs extended fingers and 45' rotation.
I've also seen solder thieves (extra pads) sometimes added for wave soldering.
If it is reflow, then a standard footprint should be fine, even one extended a little for hand soldering.
The Atmel Mega/Tiny footprints, unlike a few manufacturers, appear to be JEDEC standard. Thus, you should be able to use a footprint from another device that is also JEDEC standard.
Still using Protel 99SE Service Pack 6 once in a while...
QFP footprint libraries attached.
YW
while(!solution) {patience--;}
