Using a pointer to a function
3 posts / 0 new
How can I use a pointer to a function in AVR. I've heard of it, but never used it. how is it done?
void (*fn_ptr) (void);
fn_ptr = 0x0307;
(*fn_ptr)();
would define a variable 'fn_ptr' that points to a function that takes void parms and has a void return. If you were to set it to the 0x0307 value and then vector to it the CPU would execute from address 0x0307 onwards. You'd probably actually want to set it to a named function and then it would vector to that function (but omitting this simplifies the code above).
Cliff
PS Hey - how cool - Google says there's actually a http://www.function-pointer.org/ !!
Cliff
