Xmega BitCloud adc HAl_AdcDescriptor_t tty
4 posts / 0 new
I am using ATZB-X-233-Pro and bitcloud, it is hard to understand tty in HAL_AdcDescriptor_t
for this particular board, it has only 4 analog channels A0-A4, in halAdc.h there is a  definition
#define ADC_HW_CHANNEL_AMOUNT 8
#define ADC_HW_A               0x0200
#define ADC_HW_CHANNEL_A0      ADC_HW_A + 0x20
#define ADC_HW_CHANNEL_A1      ADC_HW_A + 0x28
#define ADC_HW_CHANNEL_A2      ADC_HW_A + 0x30
#define ADC_HW_CHANNEL_A3      ADC_HW_A + 0x38
#define ADC_HW_B               0x0240
#define ADC_HW_CHANNEL_B0      ADC_HW_B + 0x20
#define ADC_HW_CHANNEL_B1      ADC_HW_B + 0x28
#define ADC_HW_CHANNEL_B2      ADC_HW_B + 0x30
#define ADC_HW_CHANNEL_B3      ADC_HW_B + 0x38
and the other definition
typedef enum
  /** \brief channel ADC0 */
  HAL_ADC_CHANNEL0 = 0,
  /** \brief channel ADC1 */
  HAL_ADC_CHANNEL1 = 1,
  /** \brief channel ADC2 */
  HAL_ADC_CHANNEL2 = 2,
  /** \brief channel ADC3 */
  HAL_ADC_CHANNEL3 = 3,
  /** \brief channel ADC4 */
  HAL_ADC_CHANNEL4 = 4,
  /** \brief channel ADC5 */
  HAL_ADC_CHANNEL5 = 5,
  /** \brief channel ADC6 */
  HAL_ADC_CHANNEL6 = 6,
  /** \brief channel ADC7 */
  HAL_ADC_CHANNEL7 = 7,
  /** \brief ADC0 - ADC1 */
  HAL_ADC_DIFF_CHANNEL0 = 8,
  /** \brief ADC0 - ADC4 with gain 64x */
  HAL_ADC_DIFF_CHANNEL1 = 9,
  /** \brief internal signal connected to the temperature sensor */
  HAL_ADC_TEMPERATURE = 10,
  /** \brief internal signal connected to DAC */
  HAL_ADC_DAC = 11,
  /** \brief internal signal connected to VCC divided by 10 */
  HAL_ADC_VCC_SCALED = 12,
  /** \brief internal signal connected to bandgap */
  HAL_ADC_BANDGAP = 13,
  // max channel number
  HAL_ADC_MAX_CHANNEL_NUMBER
} HAL_AdcChannelNumber_t;
if I want read channel A3 should I put
ADC_HW_CHANNEL_A3
in HAL_AdcDescriptor and
 HAL_ADC_CHANNEL3
in readADC like this
HAL_ReadAdc(&adcDescriptor,HAL_ADC_CHANNEL3);
?, am I right?
and if i want to read channel of
HAL_ADC_TEMPERATURE
which parameter should I put in for tty?
Thanks you much for you help.
First of all BitCloud for Xmegas is no longer supported.
Peripheral driver library in BitCloud is not designed to be comprehensive. Just forget it exists and write your own driver.
Thanks.
Should I switch my project to MegaRF or ARM?
I'd personally go with ARM. You get more memory options (both Flash and RAM), faster frequency, 32-bit architecture and potential for growth.
