AVR32 UC3 gcc 4.4.7 from ΑS6.2sp1: Can't make __((parked, aligned(1))__ work.
6 posts / 0 new
Hi Freaks! I need your help because i am stuck!
I am reading a BMP file from SD card to SDRAM char buffer succesfully in my EVK1105
Then i want to copy the first 14bytes of that buffer or actually link to a pointer struck of the .bmp header struckt as you can see:
typedef struct __attribute__((parked, aligned(1))){
	unsigned short int  Signature;
	unsigned int		Size;
	unsigned short int  Reserved1;
	unsigned short int  Reserved2;
	unsigned int        BitsOffset;
}BITMAP_FILEHEADER;
typedef struct __attribute__ ((parked, aligned(1))){
	unsigned int HeaderSize;	 /* Size of info header */
	int Width;					 /* Width of image */
	int Height;					 /* Height of image */
	unsigned short int Planes;	 /* Number of color planes */
	unsigned short int BitCount; /* Number of bits per pixel */
	unsigned int Compression;	 /* Type of compression to use */
	unsigned int SizeImage;		 /* Size of image data */
	int PelsPerMeterX;			 /* X pixels per meter */
	int PelsPerMeterY;			 /* Y pixels per meter */
	unsigned int ClrUsed;		 /* Number of colors used */
	unsigned int ClrImportant;	 /* Number of important colors */
	unsigned char palette[1024]; /* Storage for palette       */
	/*unsigned int RedMask;
	unsigned int GreenMask;
	unsigned int BlueMask;
	unsigned int AlphaMask;
	unsigned int CsType;
	unsigned int Endpoints[9]; // see http://msdn2.microsoft.com/en-us/library/ms536569.aspx
	unsigned int GammaRed;
	unsigned int GammaGreen;
	unsigned int GammaBlue;*/
}BITMAP_HEADER;
I added on those structs the above to be able pack and align in bytesthe uint8_t sdram buffer data to the struct.
It didnt work the compiler shows the above so it doesnt work as i also noticed with my JTAGICE3 in debugging:
Warning    1    'parked' attribute directive ignored    D:\Atmel Studio 6.2 Projects\JPEG_PRJ\IJG_EXAMPLE1\src\bmp.h    25    1    JPEG_PRJ
More details:
the first bytes of my BMP file (seen from a HEX editor):
42 4d 36 e2 b9 00 00 00 00 00 36 00 00 00 28 00
which 42 4d is the first unsigned short int  Signature;
So the next 4 bytes that should be in unsigned int        Size;
are not copied or pointed correctly so i should see 36 e2 b9 00 00 but i actually see b9 00 00 00 in my unsigned int        Size of the struct because i doesnt align them. WHY?
The above is from UC3 manual
Unaligned Reference Handling
AVR32UC does not support unaligned accesses, except for doubleword accesses. AVR32UC is
able to perform word-aligned st.d and ld.d. Any other unaligned memory access will cause an
address exception. Doubleword-sized accesses with word-aligned pointers will automatically be
performed as two word-sized accesses.
The following table shows the instructions with support for unaligned addresses. All other
instructions require aligned addresses.
Table 4-1. Instructions with Unaligned Reference Support
Instruction Supported Alignment
ld.d Word
st.d Word
What that means? Its not possible to do that?
i also tried with the -fpack-struct but my code doesn't work at all! it stucks in the pll lock loop of ASF...
The only working idea that i have is to make a stupid function like this to interpret and return back a copy of the useful data in the correct types but its really ugly
uint32_t read(char * buffread, bytes_enum_t bytes)
    uint8_t x[4] = { 0 };
    for(int i =0; i<bytes; i++)
        x[i] = *(buffread+i);
    if(bytes == WORD_bytes)
        return (uint32_t) ((uint16_t) x[0] | ((uint16_t)(x[1] << 8)));
    else if(bytes == DWORD_bytes)
        return (uint32_t) ((uint32_t) x[0] | ((uint32_t)(x[1] << 8)) | (((uint32_t)(x[2] << 16))) | ((((uint32_t)(x[3] << 24)))));
        return 0;
You probably want to
__attribute__ ((packed, aligned(1))
and not
JW
OMG! I am so stupid! Thank you JW
This is a reason why we should stop programming at late nights and continue in the morning!
BTW whats the point of -fpack-struct and why it doesnt work for me? Is this some kind of automatic __attribute__ ((packed, aligned(1)) so i dont have to write it on every struct?
and not
JW
Yes
https://gcc.gnu.org/onlinedocs/g...
Dunno. It might have packed a struct used in a externally linked library which anticipates unpacked struct, for example. I don't AVR32.
Btw., there's a gcc-vs-microsoft gotcha with structs packing, it should not apply to avr32-gcc (it does not to avr-gcc), but better be aware of the potential problems.
Plus the endiannes problem with structs/bitfields in genera.
JW
Exactly!
Now my biggest problem is the endiannes. The data of the char buff is in little endian but the CPU is big endian so i get all the data swapped.
I assume the only solution is to manually swap them as i can see there are swap macros in ASF\avr32\utils\compiler.h
Yes
https://gcc.gnu.org/onlinedocs/gcc/Code-Gen-Options.html#index-fpack-struct-2696
JW
Yes, that is the "proper" way to do it.
This is known as serialisation - although commonly practised, trying to do this by forcing a struct on the raw byte stream is really an abuse of the struct - for the reasons you have discovered!
Far better to have a function the pulls the bytes from the raw stream into a struct, and another function to take bytes and puts them into the stream.
http://en.wikipedia.org/wiki/Serialization
