"An error occurred trying to load the page" on changing device (AtmelStudio 6.2)
5 posts / 0 new
I'm using AtmelStudio 6.2.1153 and working on a "solution" using ATMega324P.
When I chose Properties of my project, the properties requester (with left hand menu "Build", "Build Events", "Toolchain", …) appears.
If I click on "Device", I'm presented this message: "An error occurred trying to load the page. Input string was not in a correct format."
Are there any hints how to escape from this behaviour?
Ciao – Peter
Could be a corrupt installation. As you are out of date (6.2.1520 is latest) now might be the time to update.
clawson wrote:
6.2.1520 is latest
You mean 6.2.1502 ?
AKA "SP1"
Dyslexia Rules, KO!
Updated both AS and OS (now 1502 on Win-7). Unwanted behaviour disappeared.
Thanks to all involved between Α and Ω – Peter
